Question about Garden
No spark on my kenowa tools 10000 generator. I changed magnet on flywheel and coil
  • 211 Answers
SOURCE: week spark on honda 5.5hp gx160
Hi
I suppose is 4 stroke engine.Before adjusting the breaker points gap at .020 check if the breaker points are burned.Also check the condenser(change it).Change the spark plug with a new one with the same heat range.The plug gap is .030.
best regards savumihai71
Posted on Feb 13, 2009
cmcduncand
  • 714 Answers
SOURCE: Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Posted on Jan 23, 2010
  • 63 Answers
SOURCE: yamaha ef 2800 i generator
Check the low oil sending unit.(Make SURE there is enough oil in the unit) Take the 2 wires off and join together. If the unit starts, then replace the sending unit and put the 2 wires back on. good luck
Posted on Sep 21, 2010
  • 4088 Answers
SOURCE: No ignition at spark plug.
The ignition module should be spaced from the magnets with a thin business card. If the magnets have been scored by the module, the magnet strength may have been reduced. If you touch them with some iron, it should stick firmly. If in doubt, you may have to find a servicing dealer to get a first-hand judgment. If you tried a new spark plug without results, then the module is likely toast. Hope this helps!
Posted on Jan 11, 2011
Testimonial: "Magnets ok. Tried putting gasoline directly into carb without sign of ignition, and with new plug.Think new ignition module may be problem. Thanks."
philwalker78
  • 608 Answers
SOURCE: no spark what is air gap between coil &
Hi, gap is 8 thou. If this gap setting has not been altered from the factory it should be ok. Try a new sparkplug if you hav'nt already done so. Also try temporarily disconnecting the stop wire off the coil. If none of this works
Posted on May 02, 2011
Testimonial: "answer to my question was very helpful reguarding no spark. i had already changed the spark plug for a new one so will check the air gap now. "
Generator PM0601100, Sparks are very weak, machine doesn't start
That generator has a 20HP Honda engine. If the magneto on the engine is bad then the spark level is low. To check this you need to take the cover off the engine on the side away from the generator. There should be a flywheel with a magnet built in and there is a coil that the magnet passes by. Check the gap between the coil and the magnet. IT should be very close to each other. Honda says the gap is between .008 and .016 inch depending on the model of the engine. If the gap is ok then you need to check the coil connections and resistance with a meter.
Sep 12, 2015 | Electrical Supplies
Why do I have no spark at the coil
A few things can cause lack of spark at the ignition coil. This assumes pointless ignition system.
  • The stop terminal is intentional grounded IE stop switch on.
  • The stop circuit is shorted to ground.
Remove the plug wire from the plug so engine can not start. Remove the stop wire from the coil and try starting the engine while testing spark. If spark is now present then check the stop circuit.
  • The coil pack itself is bad.
  • Flywheel magnets are demagnetized.
These can check by seeing they attract heavy metal object strongly.
Dec 24, 2014 | Coleman Powermate Powermate 5000W...
Looking for Repair Manual for Mcculloch M48 lawnmower, but McCulloch website doesn't list one. It's a simple machine but I wanted to see if it used points (without removing the flywheel). I see no lead...
no
unless it is a real old engine , it will have a coil energized by a magnet in the flywheel
the positioning of the coil is limited to clearance to the flywheel so timing is set
as the magnet enters the area of the 2 metal arms , a current is generated in the coil that results in a spark
basically the set up is the same as for other makes of engines
Oct 29, 2017 | McCulloch Garden
Gentron pro2 6000p has no spark
With small engines, ignition is magneto. Four things can cause a lack of spark: (1) Faulty plug - try a new plug; (2) Bad, shorting, or disconnected spark plug wire - check for high voltage from ignition coil; (3) Bad ignition coil - check for low voltage at the coil input wires; (4) Magneto failure - the pickup coils next to the flywheel may be shorted, loose, or disconnected, OR the magnets on the flywheel may have lost their field or come out. I would troubleshoot this problem by checking and eliminating each of these possibilities in the above order. If all of the first three check out good; I'd have a mechanic check the magneto because this requires at least partial disassembly of the motor.
Nov 17, 2012 | Gentron 6000 Watt Propane Generator with...
What's mag
A mag or magneto is a coil of wire that is "excited" by a permanent magnet thereby inducing a high voltage to fire the spark plug with. Most single cylinder lawnmowers use mag and point systems to fire the plug. Coil is hard mounted and the permanent magnet is part of the flywheel with the points mounted under the flywheel.
A coil is a two coils of wire, one is connected to ground on one end and the other end is connected to either a set of points or an electronic switch, either of which turns on and off the current through that coil. When the coil discharges its electrical potential, its magnetic field collapses, inducing a high voltage in the other coil which is used to fire the spark plug.
Sep 30, 2012 | Generac Rv Generator - 6,500 Watt - 6.5 Kw...
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
Machine is setup correctly in flux setting, i cannot get an arc to strike,, what is the problem?
Are you sure your flux meter is working properly? Please translate.
Ignition system. Spark plug. Spark plug wire. Coil (roll of wire). Magnet (on flywheel). Magnetic pickup (coil).
Magnet flys past coil which induces an electrical current into the coil and, at speedy exit/disconnect, coil induces a voltage surge which causes a spark in the end of the spark plug. Voltage is transferred from the coil to the plug via a spark plug wire. Current is induced from the moving magnet to the coil via close proximity of the moving magnet to the coil (changing magnetic flux).
Jun 03, 2011 | Garden
I have a Toro Super Recycler Mdl 20033 ser 230000001 and up. Lawn mower will not start, there is no spark. New spark plug and fuel line. Change the magneto? Is this simple?
You may not need to change the ignition module. The "air-gap" on it may just need to be adjusted. That is, the distance between the pickup legs of the ignition module and the magnets integrated into the flywheel. You would have to remove the exterior cover and any sheet metal cowling (directs air flow off the flywheel around the engines cylinder). Then, the coil and flywheel should be visible. I use a standard business card as a gauge. Slide it between the coil legs and the magnet area of the flywheel. You should feel just a slight little rub. If it won't slide or the gap is large, no spark will be produced. You will have to loosen the screws holding the coil in place, double up the card. let the magnets pull the legs in against the card with magnets behind and retighten. Then recheck for spark. Post back if needed.
Apr 04, 2011 | Toro Power Lawn Mower
Have 10 hp Tecumsa engine and can not get ignition spark from plug. Have new spark plug, cleaned flywheel & coil with emery cloth. Have checked on/off switch for continuity. Can ignition coil be tested...
Did you check, that the magnet is on the flywheel.
When you cleaned the flywheel, did some metal rasping gather around it.
The magnet should be strong. A small steel instrument will be pulled by it.
The high voltage coil can be tested for resistance with an Ohm meter. The resistance may be some kOhm but not MOhm. If MOhm it should be replaced.
If the coil and magnet are OK, and well attached to the flywheel and aside with a minimal air gap, then the coil may be checked by turning the flywheel. As the voltage on coil ends when magnet passes by the coil should be very high, the only way for checking is with a spark plug, connected to the checked high voltage cable, the thread of the plug well connected to motor case. A spark is the prove that it is OK
Check also the HV cabel and the connection of other coil end to motor case.
I hope that this will be helpful, because I don't have your device in front of me. Some people rank such an answer with 2 thumbs (meaning useless). Better don’t rank.
Jul 28, 2010 | Coleman Powermate Premium Plus 6250W...
Ignition coil spark is weak. And where can i find
FIRST check the gap of the flywheel magnet to the magneto coil. Use a business card as a spacer and adjust the gap. If unit has points rather than electronic triggering, check those and timing and gap.
Mar 22, 2010 | Coleman Powermate Premium Plus 6250W...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
