Question about Maytag MGDC300XW Dryer
Mgdc300xw1 when i start the dryer it clicks for the first 4 minutes and the stops
Dryer is making a god awful squeaky/grinding sound when turned on. It will stop for a bit and then start up again every 4-5 minutes.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Amana NDE5805AY Electric Dryer
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
YKEHSO2RWHO starts o.k. but stop within a few minutes
that dryer has a moisture sensor probably is not sensing moisture
Jun 23, 2009 | KitchenAid KEHS02RMT Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Sounds like solenoid is faulty
Yes, sounds like a faulty relay on the main bd. Could also be the motor is starting to seize up and drawing lots of current. I would suggest a technician look at the unit and test with an AMP probe to determine where and when the excessive power is being pulled.
Nov 08, 2008 | LG DLE5977 Electric Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
TDC 30 Dryer starts but after 5 mins "clicks and stops"
its probably the relay (brown plastic box at the front under lid)! Symptoms are usually.... the dryer will go for a few minutes then shut down.... then you have to wait for it to start
May 23, 2008 | Hotpoint TDC32 Electric Dryer
Maytag MGDC300XW Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
