Question about Sony XPLOD CDX-GT200 CD Player
My sony xplod stereo only works on tuner it will show a cd is playing but no sound and the same for aux
SOURCE: No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Posted on Mar 10, 2008
  • 6 Answers
SOURCE: sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Posted on Nov 13, 2008
thefazool
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
  • 87 Answers
SOURCE: Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Posted on Jun 03, 2009
Lexdiamonzz
  • 203 Answers
SOURCE: sony xplod am/fm cd model cdx-m610 will play cds
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
Posted on May 21, 2010
My sony xplod stereo is running weird.i installed an amp and ran a remote wire but when i play CD,s the stereo turns the amp off but turns on with tuner and aux.can u help
kinda sounds like you may have used your motorized antenna trigger wire as your remote wire to your amp. if you switch out of AM/FM, it is designed to lower the power antenna, when AM/FM is switched on, it raises the antenna.
May 07, 2011 | BMW 318 Cars & Trucks
I have a sony cdx-gt45ip wen playing a cd or using the tuner my sub works but wen using the aux all bas dissaperes, the sub still has power why is this happening ?
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Mar 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
Yes, also.... I am trying to use my AUX input but "AUX" is not an option on the Source menu. The only options are tuner and CD.
In order to use the Aux, you must connect the source to aux port, then using the source select aux and you should hear the sound coming out.
Here is the link to the manual:
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Feb 06, 2011 | Sony XPLOD CDX-GT200 CD Player
I have a sony xplod gt200 The truck is a 1999 Dodge Dakota R/T The deck beeps as I scroll through the menus and volume controls but will not play music in AUX, TUNER or CD. But I get Beeps. Thi sis...
the beeping can be turned off for AUX to have sound u need to have something hooked to it if there is no sound it could be blown or incorrectly connected speakers or even a blown fuse also try RESETTING the unit
Oct 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Just bought a new car stereo (Sony XPlod CDXGT240)...Radio works fine....But the CD player will not play any sound...It reads the CD but there's no sound...
You have wired the amplifier turn-on wire to the power antenna wire by mistake.
The amplifier is turning off because it is losing the 12V signal in the power antenna wire when you go off the TUNER to CD.
Swap the blue wires, and you'll be set.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2010 | Sony Car Audio & Video
Aux jack over time seems to be faultering.
sounds like the soldering points on the jack are coming loose or shorted out. The stereo will have to be taken apart and checked out. You will most likely need a soldering iron to repair the problem
Jul 16, 2009 | Sony XPLOD CDX-GT200 CD Player
Sony Xplod stereo reset problem
My xplod deck wen I click on source it doesn't have aux anymore? How do I fix it so I can use my aux once again
Mar 01, 2009 | Sony CDX-540RF 10-Disc CD Changer
Sony cdx gt200
Nov 13, 2008 | Sony XPLOD CDX-GT200 CD Player
Friend,
Mar 06, 2008 | Sony XPLOD CDX-GT200 CD Player
Sony XPLOD CDX-GT200 CD Player Logo
32 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
