Question about Gbc HeatSeal Ultima 65 Laminating System
My GBC Ultima 65 gets too hot, how can I adjust the temp?
I have a GBC Ultima 65 Laminator and the lamination is not adhering. The materials I am laminating are coming apart.
Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Feb 14, 2017 | Gbc Office Equipment & Supplies
GBC Ultima 65 stays at the same speed cant adjust
You may have a problem with the motor or control panel switch membrane(a rubber sleeve under the buttons). Does the speed light on the panel move when you push the faster-slower buttons? If the light doesn't move it is probably your panel. If the speed light changes,but the motor doesn't change, the motor may be faulty. Does it go in reverse?
Nov 09, 2016 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Is there a schematic diagram for heatseal ultima 65 I need one.
not that I am aware of, the maint manual has a theory of operation block diagram, but no schematics.
Jan 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
My ultima 65 laminator is not sealing well on the left side. I've tried adjusting the upper tension which helps temporarily, but it reloosens after just a few minutes of use.
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
Feb 16, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Gbc HeatSeal Ultima 65 Laminating System Logo
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
