Question about Garden
Faip pressure washer pump 206376gs oil - Garden
2rns4u
  • 22 Answers
SOURCE: oil used for Cat Pump on pressure washer?
It will be a 30 wt non detergent oil probably. You could contact a Rental store in your area they will have what you need. Hope this helps. 2rns4u <*{{{>(
Posted on Jul 22, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
brado83
  • 106 Answers
SOURCE: Where can I get seal rings and o rings for my
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
Posted on Jan 02, 2010
SOURCE: What type of oil is used to fill the a FAIP
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Posted on Oct 15, 2010
Water won't go through pressure washer, even with the water on and the pressure hose off the machine, no water comes through the pressure washer.
Back behind the water outlet tube are components that have small orifices that become clogged from lime, clay, mud and other contaminants. Mud and clay mostly from well water. I've had over 60 pressure washers in the past three years. I bought them because they didn't work and I would repair the pumps unless they were cracked, then I would buy new pumps to install. It would help to know the pump model details or even the make. Faip, Himore, Annovi Reverberi etc...or even the pressure washer model number as long as it is the original pump. If it is an Annovi Reverberi then it could also be a bad shutter valve. Now there is a revised design of the shutter valve. The part number for that valve is AR42497.
May 20, 2015 | Garden
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Feb 21, 2015 | Simpson MSV3025-S Megashot 3000 PSI Honda...
What will couse the pump not to build pressure
To many things to list.
i recommend giving our free tech support person ell a call when you can be at the washer and they can walk thru the process of diagnosing it.
1-888-279-9274
Oct 21, 2014 | FAIP Vertical Shaft Pump MTPV93501
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
Power washer not spraying hard
Hi Mike
You could have one are two problems with the pressure washer.
1...pump for pressure washer worn and needs washer/seal replacement.
2...Need to adjust the pressure discharge relief valve to the needed pressure.
Please take time to rate me
Bud
Mar 28, 2013 | FAIP Powerwasher Universal Pressure Washer...
I need a user manual for FAIP-1500 Pressure Washer
Is this the one?
http://www.power-washer.us/images/stories/manuals/H150.pdf
Oct 23, 2012 | FAIP 1500 PSI Electric Power Washer
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
What oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Dec 17, 2009 | Karcher 2500 PSI Pressure Washer
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Regards
Brad
Dec 17, 2009 | FAIP Garden
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
