Question about Swintec 2410 Portable Electronic Typewriter
Install correction tape
Can't see where to run the correction tape behind the wheel. Need pictures please. Thanks. Suzanne
2 Suggested Answers
SOURCE: wheel is not setting up to type correctly
Took guide off.
Posted on Jun 04, 2009
How to install correction tape
if I remember correctly, you have a full 'spoll' with tape on the left, you thread it through/behind the metal bit where the 'hammers/roller ball' hit the paper and it is wound up on an empty spool on the right hand side.
Alternatively use tipex.
good luck
Dec 13, 2011 | Brother ML-300 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
try to see it in the sides or it might be in the bottom of the machine in some models remove the older and replace the newer.
Aug 25, 2008 | Brother SX-4000 Typewriter
We just bought a new bosch dishwasher (smu50e15au). Its easy to connect to water and power, but how do we mount it to the kitchen? Instructions are in German! Thanks, Suzanne
Hello Suzanne,
Bosch installation instructions are usually multi-language. They may appear to be in German, but on closer inspection, you should notice they are written in English below the German instructions.
However, just in case you do have German only installation instructions, you can download the multi-language version by clicking on the link below. These may look to be in German on first glance, but I promise the English version is there as well.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=vdxng6icdcso0pdmdb---jAs&UMOBID=vdxng5fcdcso0pdmdb---jAs
Hopefully, you will now be able to install your dishwasher correctly. If you need further assistance, I'm happy to explain any part of the instructions (in German or English), but you're going to have to explain what "mount it to the kitchen" means. I'm afraid that makes no sense to me at all ;)
Regards,
BElectric
Apr 12, 2011 | Dishwashers
How can we change the correction tape? We are unable to get the correction tape off. We can take out the regular ribbon. The wheels for the correction tape won't come off and we can't get below taking...
1. Use the spacebar or backspace to move the carrier to the center of the platen.
2. Open the top cover.
3. remove the cassette ribbon if installed.
4. Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, lift it up and out.
5. Pass the new tape through the left guide,behind the ribbon guide. The rough (sticky) side of the tape should face the platen.
6. Attach the feeder spool to the pin on the left.
7. Attach the take-up spool to the pin on the right.
8. Turn the take-up spool counter-clockwise until a small amount of white tape is around it.
9. Replace the cassette ribbon and close the top cover.
10. Press (CODE)+(RESET)(Q) to move the carrier to the previous position.
Dec 15, 2010 | Brother ML-300 Typewriter
Wheel is not setting up to type correctly
The keeys were getting caught in the plastic guide. Tood guide off and now no more problem!! Thanks anyway!!
Jun 03, 2009 | Swintec Office Equipment & Supplies
Trying to replace the lift-off tape on an IBM Selectric III
Open the gray lever to the right on the carrier.this will release tension on the correcting tape. Now put the supply spool on the left side and bring the take up spool across in front of the card holder. There is a little black wire just right of the card holders opening that looks kind of like a bobby pin , this is the
separator between the ribbon and the correcting tape.The ribbon is in front toward you and the correcting tape is behind. Continue feeding the correcting tape to the take up wheel and take up the slack in the tape then close gray lever.
Mar 24, 2009 | Office Equipment & Supplies
1) Use the [SPACE BAR] or [BACKSPACE] to move the carrier to the center of the platen.
2) Open the top cover
3) Remove the cassette ribbon, if installed
4)Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, and lift it up and out.
5)Pass the new tape through the left guide, behind the ribbon guide, and out through the right guide. The rough (sticky) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it.
9) Replace the cassette ribbon and close the top cover.
10) Press [CODE] + [RESET] to move the carrier to the previous position.
Mar 19, 2009 | Brother SX-4000 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Swintec 2410 Portable Electronic Typewriter Logo
63 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
