Question about Frigidaire ATF6000ES Front Load Washer
Dr error I have tried open and close empty and full washer but I can't get this error to clear. I powered it off and on on change. The washer is about 2 months old
I had the door latch replaced, it still didn't work, so they replaced the control board, it still didn't work.
Posted on Sep 19, 2007
  • 725 Answers
DR is a Door open error .. you may have a faulity door lock.. first try to see if it is not closing right.. If all closes good the door lock is not to hard to replace... let me know what you find out?
Posted on Aug 30, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 31, 2007
    I would call frigdaire as it is under warranty...
SOURCE:
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
My frigidaire front load stackable gets a code dr. model#fwtbb30ds0
Hi.
Error DR is door latch error.
Check the door lock, and ensure that it it closing and opening properly.
Disconnect power cord or trip circuit breaker for one minute to reset the error code.
If the error code comes back, then the door lock may be faulty.
The door lock may be tested removing it from the washer and reading Ohms on the terminals to ensure that it is opening and closing the circuit. An alternative way to test the lock is by jumping it, if error comes back with door latch jumped, then fault is on wiring or controller board.
Here all parts and diagrams for this appliance.
Regards.
Ginko.
May 19, 2010 | Washing Machines
Our calypso won't go through the full cycle it will either say, LD or ob? We tried evening the load then we took the close out and it still does it
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire ATF6000ES Front Load Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
