Question about Watches
Fossil blue am3541. how do you change the battery in the watch and what size battery do I need?
5 Suggested Answers
indays
  • 111 Answers
SOURCE: need to change the battery
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Posted on Aug 27, 2008
  • 203 Answers
SOURCE: How to Change battery Diesel DZ7040
dont do it yourself it will invalidate the warranty bring it back to the shop the should replace the battery free of charge. it might be more than the battery. if this helps please rate. joe
Posted on Nov 22, 2008
  • 16 Answers
SOURCE: How to change my battery on my fossil watch?
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
the type f battery will be written on the battery and you can usually find them at a drug store, hardware store or jewelry store that sells watches.
Posted on Jan 23, 2009
SOURCE: Fossil watch service centers in India
Need to change leather strap
Posted on Nov 02, 2011
Size watch battery model BQ8776 fossil blue men's watch take?
Just take it into a jeweller. They will do it while you wait, you won't have to buy 10, you won't have to buy the tools to remove the back, they have all the batteries in stock and will only charge you $6.
Dec 14, 2016 | Fossil Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
Fossil battery am-3198
Take your watch to a jeweler to identify type and possibly replace it.
Mar 04, 2014 | Fossil AM Watches
Need battery size for blue face round fossil watch
SR920 that is the size of the battery of your watch
Jul 09, 2011 | Fossil Arkitekt watch
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 12, 2011 | Fossil Blue watch #AM3574 Watch for Men
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
Aug 26, 2010 | Fossil AM3784 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
I have a fossil blue watch that isnt working. i have tried to change the battery and that does not seem to help.
take it to a jewlrey store, like sergios. They know how to fix all watches. I took my fossil blue to 4 watch stores including the fossil store in the mall and none of the stores could fix it. I took it to sergios they changed 2 batterys in like 5 minutes with no charge.
May 03, 2008 | Fossil Watches
Watches Logo
94 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
