Question about Jenn-Air Refrigerators
Jen aire fridge jfc2290vem4 why does water go the the bottom under freeser, freese then overflow onto floor
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
SOURCE: Water build up back of freezer inside
Our GE Profile leaked from the freezer door and this is what I was told by a service man to try before he came and it worked. There should be a "well" on the bottom of your freezer floor where the water runs when it defrosts. Yours is probably now covered with a sheet of ice. You can melt the ice with a hairdryer using dry towels to soak up the water as you work or really hot wet rags and ring them out in the sink. After all the ice is removed pour a small amount of warm water into the "well" and stick your finger in there and "plunge" it - like you would a clogged toilet - with your finger. This will purge the ice that blocked the drain. Check on this every couple of months to make sure you don't end up with the same problem in a year or so.
Posted on Jun 26, 2009
  • 67 Answers
SOURCE: ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Posted on Aug 11, 2009
aasc
  • 1606 Answers
SOURCE: Whirpool side-by-side fridge has so much water in
If your filter is down on the refrig kick plate , then your filter is problably the cause . Replace the filter . I have found 3 lately , that the filter seals or the actual filter was cracked , letting water drip into the drain pan , causing it to over flow .
Posted on Nov 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I get water (ice) in
Is this a NEW refrigerator? If so then you have a valid warranty service request.
If it is not, there are 2 things that cause ice build up:
1. The ice maker water valve leaking by when the water valve is supposed to be closed.
You can prove this by doing the following:
a. Ice maker OFF
b. Remove the plastic line on the back of your unit at the rubber water fill tube connection. Place it in a bucket over night or for a day. If there is ANY water in the bucket the water valve is allowing water to leak by when it is supposed to be closed.
The olny remedy is to change the water valve.
2. Te freezer compartment evaporator drain is frozen or clogged. This requires opening up the rear access cover of the freezer to clear a clog. If you just suspect ice build up you can empty the freezer compartment and place a fan blowing into the freezer compartment for over 2 hours to melt the ice in the evaporator drain.
If you need assistance with parts or anything else just respond here and I will gladly help you. I do ask that you include your model number in any future post so that I can pass you links and data applicable to your exact unit.
Thanks for choosing FixYa,
Kelly
Posted on Sep 08, 2010
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
Water in the pan beneath
As long it is not coming out onto the floor then it isk working correct but if it overflows you are getting too much moist into the refrigerator you would need to find that air leak
Mar 24, 2014 | Refrigerators
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
Fridge 102H, R600a now about 12 yrs old leaks water onto floor. I have checked the outlet pipe from the fridge and the receiving dish. The pipe is clear. The receiving dish has water in it although it...
The pan will continue to have water in it. The defrost system water drips in the pan where it is evaporated by the condenser fan blowing on it.
Does this pan overflow? Is the water on the floor coming from this pan? Or could it be coming from the water inlet valve where the water supply comes in? Does the water come out the freezer or fridge door at the bottom?
Aug 25, 2009 | Refrigerators
Ice collecting and water overflow from bottom freezer GE
Aug 11, 2009 | GE Refrigerators
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
for reallybsq
for guest.
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
56 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
