Question about Garden
What is the correct petrol/oil mix for Makita RBC2110 strimmer
  • 8 Answers
SOURCE: What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Posted on Jun 02, 2009
pippall
  • 1486 Answers
SOURCE: petrol oil ratio mix
25%to!%
Posted on Aug 09, 2009
  • 110 Answers
SOURCE: Having problems starting Makita strimmer. There is
Use 50:1 gas/oil with a GOOD QUALITY 2-cycle low-ash synthetic oil.
Remove the muffler and check the spark arrestor isn't partially blocked.
With a clear muffler, and the mix as described, there will be hardly any smoke at all.
Posted on May 09, 2010
smartr10U
  • 1305 Answers
SOURCE: What is the mix - petrol/oil for a 2 stroke
typical mix is 40:1 to 50:1... The oil containers should have a chart for the correct ounces per gallon.. I would use 40:1
Posted on May 30, 2010
Testimonial: "Excellent, Thanks a lot "
  • 66 Answers
SOURCE: My Makita Petrol Strimmer won't start
If it is a gas (petrol) trimmer...then most often it is in the on/off switch on the handle. Before you go tearing anything apart...rock the on/off switch a few times to see if it helps. www.nnyparts.com
Posted on Jun 01, 2010
My makita dbc4010 petrol strimmer was working then not used for 3 months now it wont start,plus now theres no spark
Parts: http://www.ereplacementparts.com/makita-dbc4010-brush-clearing-saw-parts-c-97_16558_10177.html?gclid=CKyA0JLti80CFQetaQodzw0DaQ Use fresh gas and oil, 2 stroke 40:1. Clean/replace air filter and spark plug.
Sep 25, 2015 | Makita Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
What is the mix - petrol/oil for a 2 stroke strimmer
May 30, 2010 | Garden
Having problems starting Makita strimmer. There is quite a lot of smoke coming out and then it stops. Have looked at spark plug -clean, and cleaned air filter. Could the problem be the petrol and oil mix.
May 09, 2010 | Black & Decker String Trimmer Cordless 12"...
Ryobi PSC 3046y3e 30 cc petrol strimmer ratios of petrol to oil
WELL IF THERE IS NO 2 STROKE OIL TANK THEN YOU MIX IT WITH THE GAS. THIS IS HOW THE ENGINE GETRS ITS LUBRICATION AND WILL BLOW UP AND SEIAZE WITHOUT IT.MOST OF THESE SMALL ENGINS RUN AR 20 TO 1. OUTBAURDS RUN AT 50 TO 1. IF YOU PUT TO LITTLE ITS NO GOOD AS MENTIONED ABOVE. IF YOU [PUT TOO MUCH IT IS NT AS BAD AS IT WILL SMOKE A BIT AND POSSIBLE FOUL THE PLUG AFTER A WHILE. I WOULD GO WITH 230 TO ONE THAT WOULD BE 20 PARTS GAS TO 1 PART OIL 20GAL GAS TO 1 GAL OIL IS THE SAME AS 5 GAL OF GAS TO 1 QUART OIL OR 2 1/2 GAL GAS TO A PINT OIL OR 1 1/4 GAL GAS TO 1/2 PINT OILM GET THE PICTURE NOW. ITS DIVISION. AFTER A WHILE OF RUNNING IF IT SMKES AND THE PLUG FOULS JUST ADD A BIT MORE GAS TO YOUR MIX AND CLEAN THE PLUS WITH AN OLD TOOTH BRUSH AND I ALWAYS MARK MY GAS CAN WITH BLACK MARKER OIL/GAS MIX 20:1 OR WHATEVER.
REGARDS, PAUL
Jun 20, 2009 | Ryobi Cultivator
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
