Question about Fujitsu fi-6110 - Document scanner - Duplex - Legal - - PA03607-B005
Fujitsi fi 6110 troubleshooting
I have downloaded scandal pro for fujitsu fi 6110 and it will not open! it just freezes my computer and does nothing
5 Suggested Answers
SOURCE: Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
Posted on Jun 02, 2008
admin734
  • 268 Answers
SOURCE: DOWNLOAD DRIVERS
Here are the drivers for that scanner , but from a diffrent website:
http://www.driversdownload.org/download-driver,9484,Fujitsu_fi-4120C_Scanner_ISIS_Driver_1_dot_5_dot_10307_dot_3002_Windows.html
Just load that page and wait about 15 seconds and the download should start....let me know if it works for you.
Posted on Oct 02, 2008
  • 16 Answers
SOURCE: fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Posted on Jan 20, 2012
SOURCE: Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Posted on Mar 21, 2013
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
Blank backsides not deleted
Hi Keegan,
Please check the blank page skip adjustment in the settings option. You may also refer to the TWAIN driver and ScandAll Pro application(if using) help guide for details.
Thanks,
ScanCare
Apr 04, 2012 | Fujitsu fi-5900C Pass-Through Scanner
Fujitsu fi5120c scanning every other page
Jan 18, 2012 | Fujitsu fi-5120C
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
Jul 20, 2009 | Fujitsu fi-5530C Scanner
Keep scandall in background
Possibly you need a more professional program. Scanning utilities following scanners (free) aren't a "Production" tool. Using PixEdit you can scan with one single click and after the scan is finished you could scan the next stack of pages. While it is then scanning the previosus document is processed with blank page removal, deskew, OCR, barcode recognition and a lot of other stuff. The reason is PixEdit using the mulitple cores in modern PCs.
Sep 17, 2008 | Fujitsu fi-5120C
May 23, 2008 | Fujitsu fi-5120C
Open Questions:
Fujitsu fi-6110 - Document scanner - Duplex - Legal - - PA03607-B005 Logo
133 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
