Scandall pro sa01038e - Office Equipment & Supplies
Scandall pro
Unchecking the box in RoboForm worked for me! Thanks!
Jul 06, 2013 | Office Equipment & Supplies
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Scanner not found scandall pro
Unplug the USB cable and delete the software.
Reinstall the software but don't plug the scanner in until the software tells you to.
Jan 16, 2010 | Fujitsu Office Equipment & Supplies
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
I have virus ..how can i get rid of this?
Ok
sino gusto funny scandal is highly infective computer virus...that replicate its own files to each drives..and that say “tropen dis ganda nakakatawa”. Worse, my current status message even displayed this: “sino gusto funny ust scandal pm nio ko”.
U Should download the given web link file to remove  Funny UST scandal virus in your PC,
http://www.geocities.com/six519/Remover.zip
just
1-download the Funny UST Scandal Avi.Exe Remover zip.
2-Double click remover.exe and
3-click on the “patayin ang tangahing virus button”.
This will automatically eliminate the Funny UST scandal AVI virus from your PC.
Happy to help u
Nov 11, 2008 | Samtron MONO TTL 13 Monitor
Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
May 23, 2008 | Fujitsu fi-5120C
Funny ust scandal virus issu
hi
install taskkiller software u get it to this link
http://www.rsdsoft.com/downloads.php4 taskkiller 2.30 download it.
then go the safe mode
kill the proceess of ust funny scandal and xmss.exe if they are.
then go to the search option check all box in search advanced optition.then go to tools -folder option and show all hidden files and folders and system files show true.
thwen search the file ust funny scandal.exe and xmss.exe in all drives then delete all files .
then restart pc.
now go to all drives if u see the ust funny in any drives del it.
your pro is solved if u not any mistake.
scan your sys with quick heal update.
Mar 28, 2008 | Microsoft Windows XP Professional for PC
Funny uts scandal.avi virus
If you want to remove that pesky Funny UST scandal virus in your PC, just
  1. download the Funny UST Scandal Avi.Exe Remover zip.
  2. Double click remover.exe and
  3. click on the “patayin ang tangahing virus button”.
Heres the link for the download!!!!!!!!!!
Jan 30, 2008 | Computers & Internet
74 people viewed this question
jasbo
jasbo
