Question about Garden
Ryobi 3000 PSI pressure washer MANUAL - Garden
5 Suggested Answers
  • 1388 Answers
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Posted on Dec 01, 2008
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
peterrance19
  • 399 Answers
SOURCE: Porter cable pressure washer starts great, but
check the seals and o rings on the connections could be sucking air
Posted on Nov 13, 2009
  • 5603 Answers
SOURCE: pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
Posted on May 16, 2010
How to hook hose to ryobi pressure washer
same as an air compressor connection,pull back on outside and insert in middle
Jul 25, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
We have a Ryobi pressure washer. Used one time. I have no water pressure.
Could be a stock Pressure Washer Unloader Valve. You can find videos of how to remove and to clean it. It is not that difficult to do. Good luck.
Sep 10, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
dont have that one but different nozzles for soap spray and valve for soap?
Apr 08, 2009 | Plumbing
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
