Question about Electrical Supplies
Prada 6500 to caravan
How do I connect my prada 6500 generater to my caravan hook up
    New Friend:
Just been looking on amaon i think you'll need this Kampa Mains Continental Adaptor Lead for Caravan Electric Hook Up
Posted on Jul 29, 2014
Have a B&S VOX 6500 industrial generator with Honda motor. Generation quit and no breakers flipped. voltmeter shows 3.4 volts on both legs when running. What happened? and how do I fix?
It may be just as simple as flashing the fields. Remove the end cap of the generator. Look for the brush holder on the top center of the housing The brushes may be worn out or the fields may have lost the residual magnetism. The brush holder has two wires going to it, a red (positive) and a ?white (negative). Hook a couple of wires to a 12 volts battery. Plug a lamp into the generator that will light up when it begins to charge. BE VERY CAREFUL!!!!! Start the generator and momentarily connect the two wires to the brush holder connections. Make sure you observe the polarity Two or three seconds is plenty. If this doesn't work remove the brush holder and check brushes.
Dec 17, 2014 | Honda Electrical Supplies
Northstar 6500 generator oil pressure switch wiring
Need to look at what your talking about, too many possibilities.
Jan 18, 2013 | Northstar Generator 10 Hp, 6500 Watt,...
I have a generac 6500 r/v generator 6 months old with @ 50 hours on it. The generator starts and runs fine for 10 minutes and then revs very high. Some times it will rev up and down like it is searching...
Make sure all the linkages and springs are hooked up on the throttle system and where they pivit is clean. Try moving the linkage by hand gently to make sure there is no sticking and litely oil where the linkages connect. If everything is working properly your internal governor has to be replaced.
Mar 15, 2011 | Electrical Supplies
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
I recently purchased a Husky 3750 watt generator to ''hook-up'' to my house. The wiring already exists so I figured I would just plug and be good. NOPE! I get it started with ease but when I try to...
Is the house dead??? Did you turn off the main breaker in the house?? It sounds like you are sending voltage to the generator.Do you have a switch that stops the power from going down the street from your generator?? 3700 watts is not a whole house genny, you need more like 6500. 5000 min, unless you are just running the fridge and the lights. Is your "plug" wired into the fusebox through a breaker or straight to the bars? You gotta check these things out.
Feb 26, 2010 | Briggs & Stratton Power Products 5,550...
Onan generator 2005 model hgjab-1038c rv generator will not keep batterys charged have to hook battery charger every time that generator is not running what should i check for this genator is in my 2005...
Go to the auto parts store and buy a "Battery Tender" solar powered, or get an electric trickle charger. Or install a battery disconnect for the period the unit is not in use; you can disconnect the battery.
HTH,
Mike...
Dec 02, 2009 | Watts Onan Portable Generator - 5000 ,...
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
Electrical Supplies Logo
287 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
