Reverse door lg washer wm8000hva - Washing Machines
I have an LG front loader washer Model VM4270HVA and I want to know if I can reverse the door to swing open to the right as opposed to the left?
Some washing machines are available with the reversible doors, but only a few of them do (and they are expensive). Most times, you would have to order the machine with the specific door opening. You can probably check with LG support for a definite answer.
Jul 13, 2017 | LG Washing Machines
LG WM8000HVA will not power on. Breakers on outlet has power will not reset
I FINALLY fixed mine at NO COST and it was quite an ordeal. The problem is that I did it all wrong from the start. Before you do ANYTHING else please be sure to check to ensure that your power button is seated properly and that it is springing back. It should feel like the other button when you push it. After ordering hundreds of dollars of parts I finally thought what else could it be. That's when I got the bright idea to check the button. Please save yourself the hassle and money and check this first. If it isn't that it is probably the power cord, the main control board (top back left corner under the lid.). Hopefully this will help many people who can learn from my mistake.
Feb 26, 2013 | LG WM8000HVA 29" Front Load Steam Washer...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I want to change my LG front load washer so i will open to the right
Sorry, but the door on the washers are not reversible, only the dryer doors are reversible. I'd suggest using a low profile telescopic style dryer vent to allow you to put the washer on the left side without worrying about the dryer vent location. You can get longer dryer power cords if needed, and water supply extention hoses, or just longer hoses if needed. The drain hose is usually long enough to still reach the drain. I have done this many times.
Sep 28, 2009 | General Electric WCVH6800J Front Load...
LG Tromm door reversal
IF YOU SWITCH THE DOOR YOU MIGHT WANT TO MAKE SURE THERES NO SWITCH OR ANYTHING THAT THE DRYER READS TO SAY THAT THE DOOR IS SHUT OR OPEN IF NOTHING THEN IT SHOULD BE A PRETTY EASY SWITCH
Mar 09, 2009 | LG DLE2514 Electric Dryer
Need to reverse dryer door on Model #FEFB9200ESO
instructions are available here
thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | LG WM-2277HW Front Load Washer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Doors
First Read your owners manual and see if the doors are reversible. They may or may not be?
at one installation we did the washer was not reversible so we put the dryer where the washer was and the washer where the dryer was, customer was very Happy and was Happy to pay $$$
May 25, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
223 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
