Question about Intel Motherboard
Epox 4B2A2/+/L Intel 845 mobo error code
At start up the led on the mobo lights up C3 and then beeps at me. System doesn't start.
  • Ryan Bosworth Mar 23, 2008
    yea i turn on the computer and it goes to the dell loader in the beggining, then begins to beep from the motherboard and doesnt go anyfurther. windows will not load. what is the deal
    motherboard just beeps at me when i start up. it goes through the dell loader screen then never starts up windows, just beeps. i dont know whats wrong.
  • 94 Answers
Check the installed hardware if it is connected properly ex: Video Card, Sound Card, Memory Card. Check also your keyboard and floppy drive if it is properly connected. Beep codes means something is not inserted/connected properly or something is already busted that must be replaced. In your case, check all the connections in your motherboard first.
Posted on Aug 01, 2009
Check if the harddisk is registered in the standard cmos utility and advanced cmos utility, if not register it
secondly, check if the hard disk's partition is ok and check if the os is not corrupt, if corrupt install a new one
Posted on Feb 16, 2008
4 Suggested Answers
  • 135 Answers
SOURCE: No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
SOURCE: Intel 845 GVSR
i have 845 gvsr m.b., 512mb ram, 80gb hdd, dvdr/w but my restart
Posted on May 08, 2009
  • 2678 Answers
SOURCE: 1-5-1-1- beep code on Intel sds2 Mobo bought 2 new processors
Here are the BIOS beep codes
http://www.computerhope.com/beep.htm#05
As you will see 1-5-1-1 does not appear in the list are you sure you've counted correctly?
Posted on Sep 07, 2009
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Dell Studio XPS System 435MT beeps?
Here is a list of beeps that can help you:
1 beep BIOS ROM checksum in progress or System board failure
2 beep No memory modules detected
3 beep System board failure. Power LED is blinking amber
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller test failure
4 beep Memory failure
5 beep CMOS battery failure
6 beep Video card failure
AK
Jul 17, 2014 | Dell Computers & Internet
My Dell optiplex 790 desktop compuer doesnt boot, no beeps and key board isnt working.the power fan works and no light the mother board is on,what should i have to make my comp fixed?
Not sure about dell mobos.. Asus usually has some led indicating there is current running on the board even if it's off..
From my experience i can say if there is no beep that means the memory is defective, preventing the system to do P.O.S.T. (power on self test) which is where the beep comes from.
Being a Dell system i'd say you should go for it's help desk.
If that's not a option you can remove the memory and see if there is a beep, if not, the other part that can prevent the system to POST is the processor.. If you have another (working) system you should test both memory and processor there.
Dec 05, 2013 | Computers & Internet
2 LONG BEEPS BUT THE PC STILL BOOTS mobo asus m4a785-m phenom ii x4 945 c3 4 gigs kinston ddr2 800 thermaltake 600w pny gtx 460
Beep codeswere first introduced by IBM on their first PC as a means of trouble shooting failures. The two long beeps are not familiar, but who knows. look at the following site for some of the Bios beep codes.
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml#Phoenix BIOS
Jan 03, 2011 | ASUS M4A785M (890552666775) Motherboard
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
T6520 emachine. when i turn it on the fans start, the keyboard lights flash, the monitor led turns green (getting a signal) and about the time i'd expect to see some display image and/or hear the mobo spkr...
Based on your previous troubleshooting, with both built-in video and alternate video card, I'd guess you have a bad mobo. Anything else that was wrong with it (RAM, CPU, etc) and you'd get beep codes.
Sounds like it's time for a replacement board. If the eMachine is out of warranty, it might make more sense just to go ahead and upgrade now, as they are so inexpensive. If you are capable of replacing the board yourself, that would be the cheaper alternative.
Hope this helps - remember to rate (and great troubleshooting, btw!)
Scott
Oct 06, 2008 | E-Machines Computers & Internet
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Intel Media Series Intel G33 chipset micro atx no post no boot after crazy fan
make sure you have seated all the cards properly, take them out and reseat them including the ram. Make sure your IDE cables are plugged in properly as well.
Restart the computer and if still no post then yes unfortunatly for you its the mobo =(
Dec 03, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel Motherboard Logo
80 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
