Question about Sewing Machines
Husqvarna viking 990
The wire loop in the front thread guide seems to be "pinching" my thread... making it very tight and not easy to pull.
  • Sewing Machines Master
  • 7,365 Answers
Try checking the wire loop and see if there is a burr on it an if there is try using a small file to take the burr off
or check to see if the wire loop is bent, it may have to be replaced.
Posted on Jul 25, 2013
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
kent581
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
SOURCE: husqvarna viking emerald 183 - horizontal bobbin
I know the answer is a little late now...
I bought the machine a month ago and find that the bobbin picture is a bit misleading... i find putting the bobbin in the case, pushing the thread down over the hook thing (like in the picture) but then cutting the thread really short and putting the plastic cover on seems to work!
it is actually vary easy once you get the hang of it!
Posted on Feb 16, 2010
Needle only moves a little and then beeps saying needle up when the peddle is pushed. Machine will not run.
Good day Po!!!
Sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble; >Do this;
1.Top tension to tight >loosen tension 1 turn
2.Machine improperly threaded >check threading
3.Thread twisted on guide post > "
4.Thread twisted out of tension > "
5.Take up spring bent or broken >Check action of spring
6.Thread jumped off pull off finger >Check threading
7.Needle bent or burred >new needle
8.Bad cone of thread >try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tension spring to tight >Loosen tension slightly
2.Bobbin threaded wrong >check threading
3.Bobbin wound to tight or uneven >try new bobbin
4.lint or thread on bobbin case >clean inside case
5.Lint or thread inside hook >clean inside hook
6.Bobbin case nicked bent or burred >check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred >change
2.Needle set in crooked >Check
3.Thread jumped off take up spring >check threading
4.Thread jumped off pull off finger >check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth >Tighten bobbin tension
or loosen top tension.
2.forming loops on bottom of cloth >Tighten top tension
3.Bobbin placed in case incorrectly >remove and replace
4.Bobbin thread slipped from under >check threading of
tension >bobbin case
5.Lint or thread in top tension >clean between tension discs
Please just add a comment if you did not solve your problem by doing these procedures.
If this solution helps you please do not forget to testify and rate me...Thank you so much for using fixya!!
Jul 08, 2011 | Husqvarna Viking 1
Viking Sewing Machine
Be sure you haven't missed a loop while threading the bobbin. If that's not it, check how well the bobbin is turning on the spindle. If it is threaded properly and you have cleaned it, I suspect you will find some damage to the bobbin that is causing it to bind on the spindle. If you have another bobbin, try it and see what happens.
Post back to let me know what you find.
Oct 17, 2007 | Husqvarna Viking 1
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Viking husqvarna classica 100, thread tension
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Unbalanced lower looper thread wraps aaround the
Loosen the upper tension looper thread by turning the dial to a lower number. The upper tension looper is to tight and pulling the lower looper thread up. Also might want to loosen or tighten the left or right needle tensions depending on the results you get. It will be a trial and error exercise to get the correct adjustment between the loopers and needle thread tensions. Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Oct 02, 2009 | Husqvarna Huskylock Computerized 910
How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Sep 19, 2009 | Husqvarna Viking 1
Can't remember how to thread my #1 Viking 1200 sewing machine... thanks for the help. Eloise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Aug 28, 2008 | Husqvarna Viking 1
Bobbin?
DO NOT RESET THE TIMING!! The timing is off on maybe 1 in 100 modern Husqvarna machines. For the user to change the timing is turning a simple fix into a complicated and expensive fix.
If the top thread is "looping up on the bottom" then you have a problem with the tension on the top thread. Here is what to check:
1. Thread the machine all the way through the eye of the needle. Don't go under the foot.
2. Pull the tread to the side. While pulling, lower the presser foot. You should see the needle bend as the thread gets tight. If not, you have no tension on the top thread.
3. With the bobbin in the case, hold the needle thread and turn the handwheel to bring the thread up. Watch through the cover to see if the thread passes over the bobbin from left to right. When it gets to the right side, the take up lever should pull the slack out and the thread should be pulled up. If it comes part way across but does not pull up, make sure the thread is in the take up lever. If you never see the thread, remove the bobbin case and turn the hand wheel. You should be able to see the hook pass behind the needle while the eye is still below the level of the hook. If the eye is above the hook as it passes the needle from right to left, then and only then consider timing the machine. If the hook passes above the eye but doesn't catch the thread (bobbin case out, needle plate on, presser foot down) you probably have a problem with your needle. Put in a new needle and make sure that the flat side is to the back.
99% of the time when a Husqvarna is not picking up the bobbin thread, something simple has been overlooked. Your symptom of looping on the back of the fabric indicate either a threading or tension issue in most cases, not timing.
Aug 04, 2008 | Husqvarna Viking 1
Loop formation between bobbin and needle
Not enough info provided but will provide procedure for testing tensions:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jul 14, 2008 | Husqvarna Freesia 425
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
