Whirlpool washer model wfw9550ww00
Pause/cancel button stuck on, can't open or run a load.
  • Chris knight Aug 19, 2013
    Thanks for all of your suggestions, first let me tell you what I have done already(this should narrow the problem down). I ran a diagnostic and came up with a F20 code, so I replaced the pressure switch and inlet valves. Had the same problems so I took new parts off & returned them. Also, let me say that I first checked all hoses & drains, filters etc. everything flows properly. Even surprised bottom drain/filter was empty, no change, toothpicks etc. I still have a washer that thinks it is in an "add a garment" pause, it never goes into a wash cycle & I have to unlock door manually everytime. Does anyone think this may be a door latch assembly issue? Or is it the CCU? If it is the later than I may have to give up & start saving for a new one, though my washer is only two years old, I only paid $500 for it. Wish I would've opted for the extended warranty!
F#code keeps flashing on washer did what manual says to do but nothing changes can you help
The "F1" error code on a Whirlpool Cabrio washer means that the machine control assembly has failed and you must replace it. Order a new assembly from a Whirlpool parts dealer. The "F2" troubles code means that a key on the user interface or keypad is stuck. Look at each key and try to unstick it. Always hit the "Pause/Cancel" button to try and erase the error code. Try restarting the load.
Oct 18, 2014 | Whirlpool Washing Machines
Washer won't run just makes humming sound
hi the fault may be down to the brushes on the motor
regards
shaun
Nov 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F 26 Code that won't go away
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
Paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Mar 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
