Question about Samsung Digimax S500 Digital Camera
Hello trying to replace the upload cord, know where I can get another at retail? Also, do you know what the type/name or number of the adapter is?
  • 75 Answers
You are referring to the USB cord. You should be able to get a replacement at any big retail store like BestBur or Radio Shack. Take your camera with you to ensure that you get the correct size connector. If your pictures are on the removable SD memory card, then an alternative would be to buy a card reader (about $10) and stick you memory in it to upload to your computer.
Posted on Aug 30, 2007
SOURCE:
DC to AC power cord Do they still make them if so under what name or product name?
"DC to AC" cords are not really a common item. They are called "Inverters". Typical inverters are 12VDC to 120VAC and are found in mobile applications to operate houshold current type (120VAC) devices. Inverters cost many times more than thier "AC to DC" or "AC to AC" sisters.
An "AC to DC" and "AC to AC" cord however, is a very common item. They are usually called simply "AC Adapters" and are sold in many electronics stores (Best Buy, Fry's, etc.) and electronic specialty stores (Radio Shack) and electrnics suppliers (MCM, etc.) Nearly all of them are designed to reduce the voltage in your home (120 VAC volts alternating current) to a different but usually lower voltage that is either AC or DC.
In order to select the proper AC adapter, you need to know:
(1) Input Voltage - this is the outlet voltage - often 120 volts in N. America, (2) Output voltage - this is the voltage the device needs and is often indicated near the jack, The adapted must match this voltage. (3) the device voltage type - this will be either AC or DC. The adapter must match the type as they are NOT interchangeable. (4) the size and type plug on the cord that will allow it to mate properly with the jack. There are many, many types and it should be tested for fit prior to plugging in and must match the device jack (5) the power requirements - this is usually shown as a number in Watts (w) and / or Amps (a). It is very important that the apdapter power rating is equal to or greater than the amount specified by the device. Failure to meet the requirements above can cause failure of the device, adapter or both.
I hope this helps and good luck!
Feb 08, 2013 | Uniden BC60XLT-1 Handheld Scanner
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Hello I have some movies on my laptop but now I want to wach them on tv on my TV I have only scart-input,experts told me I need a cable with D15 connecting from my laptop to one transformer to my...
Most Laptops use S-Video as a way to display video on your TV screen.
You can pick up a S-Video cable at your local Electronics store IE Radio Shack. Before purchasing the cable ensure your TV has the correct input.
The four main types are (in increasing quality):
1. S-Video [2 types: 4Pin as in picture'7Pin]
Port: http://www.coloredhome.com/video/s-video...
Cord: http://akamaipix.crutchfield.com/graphic...
2. VGA
Port: http://upload.wikimedia.org/wikipedia/co...
Cord: http://www.thisishowyoudoit.com/blogimag...
3. DVI
Port: http://vocaro.com/trevor/blog/wp-content...
Cord: http://www.tech-faq.com/dvi-hdtv-connect...
4. HDMI - also transfer sound signal
Port: http://media.bestofmicro.com/,2-3-49323-...
Cord: http://www.k1cable.com/images/hdmi_000.j...
All of these do the same thing: The laptop sends the video information through the Port and the Cord. Your TV Recieves that information in its port. Numbers 1 to 3 do not transfer sound, so you will need a separate adapter for your headphone to TV Audio. #4 HDMI transfers both sound and audio data, so you won't need a separate cable for sound.
Check if your TV has corresponding ports. If not, you can buy adapters. This is an example of a VGA to RCA(Red/White/Yellow analog cables) and S-Video
http://img.alibaba.com/photo/52306528/VG...
Thanks for rating good luck
Jan 13, 2011 | Computers & Internet
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
I can't determine the polarity of my GPX PDL705 portable dvd
I have uploaded the GPX PDL705 manual to this site today. If you check tomorrow they may have posted it by then.
If you look at the small print on the adaptor it should indicate by diagram Voltage output, current capacity, type and tip polarity by small diagram. Most adaptors are 'positive' -- but if you are unsure do not plug the adaptor into the device because it will fry it!
Dec 05, 2008 | GPX PDL705
Login Screen changes
Hi there is an excellent site http://www.dougknox.com/ where you can get a fix for this problem once on the site click on the left hand side WIN XP UTILLITIES then choose from the list it brings up Fix WINDOWS LOGON follow the instructions and it should solve the problem.This is a registry fix so as in all cases when dealing with registry fixes make sure you back everythin up first.
Jul 25, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Power supply problem
You can get from the manufacturer, however many retailers carry universal power cords, ie radioshack, best buy, circuit city. To get just an end to splice on to your existing cord that would be from the manufacturer as those are proprietary. Just a word of warning if you are going to replace the cord you're lookin at about 80 bucks for a universal, as laptops use odd voltages at high amperage. Bring it in to retailer or bring the model number so it can be matched up properly. Good luck, hope this helps.
Sep 14, 2007 | Compaq Presario 2100U Notebook
The Infamous Protron PLTV-32
I found a replacement adapter at LCDPAYLESS.COM it will arrive soon I will log-on as soon as I get it to let you know if it works. I never ordered anything from them before hope it works. Also i will keep my receipt and seen it to protron to have them refund my money
Jun 25, 2007 | Protron PLTV-32 Television
Samsung Digimax S500 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
