Question about Plumbing
Blanco linus how do you tighten the blanco linus faucet? there is not manual or instruction anywhere and i cannot figure out how to do this... thks
  • 374 Answers
SOURCE: Blanco Faucet Side Sprayer
It may be a result of extreme temperature changes from the time you tightened the shank until the time it broke however this is very unlikely.Typically the shank only needs to be tightened until it is stationary and immovable by normal operating stresses which is a very low torque value. As a general rule of thumb I use finger tight and an additional quarter turn. I once used epoxy and a short nipple to resolve the same issue but I had the advantage of having a pipe threading machine to fabricate the perfect size nipple and used a large washer and coupling to finish it off. If you try a new shank try tightening it as little as possible and I believe this will resolve the issue. Thanks for using Fix Ya and I hope this is of assistance to you.
Posted on Nov 09, 2008
  • 1584 Answers
SOURCE: Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Posted on Jan 26, 2010
  • 349 Answers
SOURCE: Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
Posted on May 24, 2010
  • 349 Answers
SOURCE: remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Posted on Jun 13, 2010
  • 8 Answers
SOURCE: leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Posted on Mar 11, 2012
Faucet is loose. How do I tighten it up?
Sorry to read about your problem, I hope this helps you out.
you have to go under the sink and tighten the bolts, you may require special tools to tighten..or contact a handyman
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Blanco Classic Single Handle Faucet with...
I have a blanco kitchen faucet that is about 5 years old. it seems to be leaking from inside the unit itself , problem is , trying to figure out how to get it apart to repair it.
behind the handle there should be an allen screw under a crome cap . once you reove the screw the upper metal ring should just unscrew then there are a series of o rings that can be replaced
good luck James
Dec 26, 2010 | Blanco Classic Single Handle Faucet with...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
How do I take off handle
Yes, it will be a small allen key that needs to be loosened before you can remove the handle.
Jun 24, 2009 | Blanco Classic Single Handle Faucet with...
Repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Apr 21, 2009 | Plumbing
Nov 08, 2008 | Blanco Plumbing
Plumbing Logo
16 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
