Question about Kenmore Washing Machines
HOW TO REMOVE AGITATOR ON MODEL 110 FROM SEARS
TYPE 111 - MODEL 110-4685290 NEED TO REMOVE THE AGITATOR AND TUB TO CLEAN DIRT ON OUTSIDE OF TUB...TKS.
Jimster
  • 240 Answers
SOURCE: Removing Tub from Maytag Atlantis Washer
I do believe that when you remove the four bolts, it should come out. Sometimes you have to use a little force and shimmy left to right to get it to break loose (no hammers please) especially if you have a lot of scum build-up from soap. They can really be a bear sometimes to remove. Maybe put your foot in the bottom of the tub and hit it on both sides to work it free. Good Luck!!! Jim
Posted on Sep 09, 2007
aborcass
  • 2651 Answers
SOURCE: model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Posted on Mar 10, 2008
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
  • 18 Answers
SOURCE: Trying to remove inner tub of a Kenmore 60 series washer.
my friend had same problem with his machine. instead he filled it with boiling water and dumped a bottle of no name brand liquid plumber in and let it run through. the smell was fierce but it cleaned it out. this is probably not the smartest or safest way but it is easy. oh one more word VENTILATION!
Posted on Feb 23, 2009
SOURCE: Sears Kenmore 80 series washing machine Model 110.26832691
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
Posted on Apr 30, 2009
Owners manual for sears kenmore washing machine type 588-08 model number 110-21102011
Many Kenmore appliance manuals are available from the Sears Parts Direct site: http://www.searspartsdirect.com/ . The manual page for the 110.21102011 washer is http://www.searspartsdirect.com/partsdirect/user-manuals/11021102011-Kenmore-Parts-Washer-Parts-manual?searchTerm= if you want to read it in your browser. (A PDF plugin is needed.) The direct link to the manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/1009787L.pdf if you want to read the document in your PDF reader software.
The parts diagrams may be more useful for how to remove the agitator. Those are available here: http://www.searspartsdirect.com/kenmore-parts-washer-parts/model-11021102011/0582/0153200.html?searchType=modelSearch&prst=&q=11021102011&searchTerm=11021102011&shdPart= . The agitator is shown in the Basket and Tub Parts diagram: http://www.searspartsdirect.com/kenmore-washer-parts/model-11021102011/0582/0153200/K1103004/00003.html .
I hope this helps.
Jul 30, 2015 | Kenmore Washing Machines
Kenmore 70 series model 20722990 tub 110 water
The drain sump is clogged with dirt and needs to be removed and cleaned thoroughly.
Some tips from this video: drain cleaning
Nov 20, 2013 | Kenmore 20722
How to remove agitator from Frigidaire washer - grime coming out from under agitator.
that most likely is coming from the tub seals and not dirt under the agitator,the tub seals are made from black rubber and metal.send the model number off of the washer or go to this site and look up your machine and it will have a breakdown on the agitator and you can see how to get it out.
http://www.searspartsdirect.com/partsdirect/index.action
Apr 07, 2013 | Frigidaire Washing Machines
Suspect we have a finishing nail under the agitator...how do we remove the agitator? model KAWS750LT1 I know how to get the fabric softener dispenser off
To remove the softner dispenser just grasp the outsides of it and pull up,or wiggle it side to side.It fits into the agitator by pressure and has no clips or screws.
If you dont find the nail there under the agiator the inner tub would need to to removed to see if it's in the outer tub. To remove the inner tub a special tool is needed.
Gene
Aug 20, 2011 | KitchenAid Washing Machines
I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Dec 26, 2010 | Kenmore Washing Machines
Kenmore model 24054 washer that leaves dark streaks on clothes.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to access the console, pull the cabinet, agitator(s) and tub if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=ef7d852e2285d2944a8b015a847b15db
You don't have to pull the pump, motor, transmission and drive tube to pull the agitator and tub.
HOWEVER:
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut. However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner
nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
With the agitators and tub out, it's relatively easy to clean out the gunk that builds up over time.
Apr 25, 2010 | Kenmore 24052 Top Load Washer
Washer leaves trash on clothes when finished. has been doing this for some time now. some of the particles resemble dried tree leaves.
It sounds as if there is a soap buildup in possibly a couple of places and it is coming loose then ending up on your clothing. If you changed brands of soap this can happen also. The soap buildup can be under and inside the agitator. It can manifest itself in large calcium type flakes in the washer when it finally breaks down and you see it. You can remove the agitator by opeing the top of your agitator and removing the retaining biolt then lifting out the agitator. Use a putty knife and scrape off the inside of the wash tub under the agitator. Also take the agitator either outside or to the bathtub depending on weather and scrub it clean on the bottom and on the inside of the agitator. If after all of this you still have that same material show up you may have to remove the wash tub itself and clean the outer tub with a putty knife. There is a special tool that locks into the 4 slots of the tub nut used to remove the tub nut. You can buy it at most appliance part centers. Tell them you need a tub nut removal tool for a kenmore / whirlpool top loading machine and they will walk back and get you one straight away. Good luck andI I hope this resolves your problem.
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Series 80 Agitator top dosent work
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Following is an illustrated description of the above.
Jan 09, 2010 | Kenmore Washing Machines
I need to clean around the washer outside of tub how do I access
REMOVE THE PLASTIC COVER ON TOP OF THE AGITATOR AND THEN THE LARGE BOLT OR SCREW THE RETAINS THE AGITATOR TO THE DRIVE HEAD, LIFT IT OUT.
Aug 27, 2009 | Washing Machines
Amana ALW780QAW mold in agitator
actually sounds like fabric softener residue with dirt mixed in...it's almost like a wax if thats it. probably just have to clean it regularly..good luck! :)
Jun 14, 2009 | Amana ALW880WH Top Load Washer
Washing Machines Logo
46 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
