Question about Samsung DLP HL-P5663W 56" TV
Shuts off after 30 seconds of Play
Hi My TV is rather new and when i turn it on it plays for about 30 seconds or so and then it shuts off. As it turns off Three flashing lights apear about once every second in front of the tv. i tried unpluging it for 30 seconds but the problem continued. Im not sure what else I could do. Thankyou for your time and consideration.
Re: Shuts off after 30 seconds of Play
When that happens it could mean your bulb needs replacement. You can replace the bulb yourself on most TV just heck the back of the owners manual.
Posted on Oct 11, 2007
  • 375 Answers
Is the set still under warranty,if so call for service if not when you turn it on try to listen near the side of the unit for a fan noise or high voltage arc sound and do you see light on the screen or in the rear of set.
Posted on Aug 30, 2007
0 characters
3 Points
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
TV wont turn on.
This case needs to diagnose by a qualified technician
Nov 28, 2008 | Mitsubishi Standard (CRT) Televisions
TV shuts off.
I need the pin for this tv
Sep 06, 2008 | Toshiba 32A33 32" TV
Sylvania SRC21134
This could be a High- Voltage shutdown circuit problem. The reason it will stay on longer with a bright picture, is the high voltage is slightly reduced, not allowing the shutdown circuit to shut off the set. But I believe your problems to be in the shutdown circuit.
Jan 03, 2008 | Sylvania 6413TC 13" TV
Turns on and immediately shuts off
check for sleep mode and whether the timer for sleep mode is on or not, if sleep mode is on lets say 30 min or 5 min , ur TV will turn off automatically after that much time
Dec 16, 2007 | Panasonic CT-32HX42 32" TV
Shuts off after about 5 minutes
Hello, please check the main board for cold soldering, especially the area around tuner. If you need more info please advice. Arpi
Apr 26, 2007 | RCA F32632SB 32" TV
Samsung DLP HL-P5663W 56" TV Logo
211 people viewed this question
Top Samsung Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Samsung Standard (CRT) Television Expert? Answer questions, earn points and help others
