If u have OS installed on hard drive there is a separate partition on hard drive that hold OS files in a safe place in case u lose ur recovery disk u can get ur system reset to Factory Default without recovery disk
if u want to factory reset ur system without recovery disk u can do following but it is always safe to have recovery disk in store in case ur hard disk crashes and u are in trouble
Factory Reset W/o Recovery disk
Compaq/HP: When you first turn on the laptop and see the Compaq/HP logo screen, press the F11 key (you need to do this before the Compaq/HP logo disappears).
if u want to make recovery disk with ur running system u can do this
The recovery disc program prompts you at first startup, but if you ignored
it, you can search for it in the start menu. Once it's running, it
prompts you through step by step.
the program is called "recovery disc creation wizard" u can type rec in search and u can find it easily
for more detailed procedure read this it is for desktop but steps remains the same
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00882383
PLS RATE ME FIXYA FOR HELP !!
DOnt worry, you can create a recovery disc by your own.. which is your laptop
