Question about Garden
Hozelock AC2 is still leaking when it is in the off position. It is opening and closing but water is still getting through when it is in the off or auto position
2 Suggested Answers
turops
SOURCE: the motor in my hozelock ac2 keeps opening and
Same problem for my Hozelock ac2 after two years working couple times everyday. No warranty, no Service Center nearby. Two options: discard it or repair it myself. Using a small screwdriver I removed the front cover and then the sealed transparent lid covering the keyboard. Humidity was damaged all contacts so I cleaned using compressed air, put new batteries and set up all again. My Hozelock ac2 is working again. I think the product life cycle is two years and as usual also has "planned obsolescence". -Arthur RS
Posted on Mar 29, 2012
Hozelok Titan 2000 pump not pumping. Electricity is getting through, pump making a funny noise but not pumping.
You have to prime the pump first. Turn off the pump, remove the priming cap, fill with water, close, then run it. Repeat as needed to get water pumping.
Sep 11, 2013 | Hozelock Garden
Hozelock instructions
Copy following link to identify Hoselock timer and watch instruction video for each model:
http://www.hozelock.com/watering/auto-watering/water-timers.html
May 09, 2013 | Hardware & Accessories
How can i fix a leak inside my hozelock auto reel
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
Jun 01, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Hozelock Regulator 2702 leaks through small hole on side
You have this in the wrong product category, if you need assistance please post it correctly. Thanks
Mar 22, 2012 | Cars & Trucks
I have a Hozelock super cascade 100 pump for a small pond. The water flow is very poor and I have cleaned the filter. I believe the pump is about 10 yrs old, is there anything I can do?
You need to put a vacuum gauge on it and see what the vacuum is. There are ways to increase the vacuum pull. You can shim the impeller closer to the volute casing, get it as close as possible without rubbing each other. If the parts are extremely worn, you may have to replace them. What about your pump seal? Is it leaking water? You could be sucking air in there, this would decrease your suction as well. Good luck.
Jun 18, 2011 | Garden
The motor in my hozelock ac2 keeps opening and closing and the display is blank. I've put in new batteries but the problem persists. Any advice on how to fix this?
Apr 20, 2011 | Garden
I have a Hozelock 2475. Which I need to have just bought a new hose for but i've mislaid the original assembly instuctions can I get same on line.
This is a link to a downloadable PDF file on our website , hope it helps http://www.hozelock.com/uploads/pdf/instructions/watering instructions/33714-002 2N1 REEL.pdf you can also get help from us on Facebook or at info@hozelock.com
Apr 19, 2011 | Garden
I bought a Hozelock Ultra 9 (model 2684) last year for watering the garden and cleaning the car.It now leaks very badly from around the trigger. Can I take it to bits and mend it? Are there any...
HI - Simon fom Hozelock. I am afraid they are not repairable in this area. The most common cause of this failure is due to ice forming inside the gun and forcing the internal plunger and O rings out - causing a leak. All sprayguns should be protected from freezing. If this isn't the cause (only you know !) And it is 1 year old, we would replace it under warrenty contact us for help www.hozelock.com for details. Simon
Mar 09, 2011 | Hozelock Garden
Hi, I have a Hozelock Cyprio 1313 filter I inherited with my pond and new house. I Cant seem to get it working without water pouring out the two holes on the top and elsewhere. I'm not sure if I am putting...
Hi - I'm Simon from Hozelock. There should be a big o ring that goes between the lid and the tank to make a seal - is that missing ? Also there should be clips that hold the lid to the tank. Both pieces are available as spares, at www.hozelockservice.com - any probs contact info@hozelock.com or @hozelock (twitter) or Hozelock on Facebook. Best wishes.
Feb 25, 2011 | Sport & Outdoor - Others
How do I set the programme on a Hozelock auto watering timer AC+
http://www.hozelock.com/uploads/pdf/instructions/watering%20instructions/2705%20AC1.pdf
Jun 04, 2010 | JVC Everio GZ-MG37 Camcorder
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
