Freezers Logo
A
Anonymous Posted on Jul 24, 2013
Hotpoint fza54 High temp light keeps coming on food still frozen put on fast freeze till goes back off! Stays off for 24hrs then comes back on
5 Related Answers
Tech007
Ronald Rousseau
  • 63 Answers
  • Posted on Aug 29, 2007
SOURCE: Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Anonymous
  • 291 Answers
  • Posted on Sep 09, 2007
SOURCE: temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Anonymous
  • 1122 Answers
  • Posted on Jun 15, 2008
SOURCE: Hotpoint FAZ50 Frost Free Freezer
IF NOT THE THE DEFROST TIMER YOUR DEFROST HEATER OR DEFROST TERMINATOR IS BAD,REMOVE BACK PANEL INSIDE THE FREEZER YOU WILL SEE A LONG SINGLE OR DOULE POLE SHAFT THIS IS YOUR HEAT REMOVE BOTH LEADS ONE ON EACH END PUT YOUR VOLT METER ON OMES AND PUT ONE LEAD ON EACH END IF YOU GET ANY KIND OF READING YOUR HEATER IS STILL GOOD AND THE LITTLE ROUND CLIP ON TERMANATOR IS BAD, IF NO READING THE HEATER IT IS BAD,REPLACE-GET THE MODEL NUMBER INSIDE FREEZER AND GO TO LOCAL APPLIANCE PARTS STORE TO GET HEATER-REPLACE AND PUT BACK TOFETHER AND YOU SHOULD BE GOOD TO GO,ALSO MAKE SURE THE FREEZER FAN IS NOT STUCK AND TURNING,IF NOT TURNING SPIN IT WITH YOUR FINGER AND SEE IF YOU CAN GET IT GOING AGAIN,LET ME KNOW
Anonymous
  • Posted on May 05, 2010
SOURCE: freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
Anonymous
  • 43501 Answers
  • Posted on Aug 12, 2010
SOURCE: hotpoint fza21 fast freeze not working
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
1helpful
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 • Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
1helpful
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 • Freezers
Freezer doesn't work
1helpful
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
2helpful
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
