Question about Freezers
Hotpoint fza54 My high temperature light keeps coming on for no apparent reason. is the freezer on its way out?
  • 9 Answers
SOURCE: hotpoint
This more than likely is because your evap.coil is frosted up do to a part failure with the defrost system. Look at the freezer back panel is there alot of frost growing all over it this is the number one sign. Either way take the back panel off and make a visual check. If there is alot of frost first get a multimeter and set it on Ohms with alert chime meaning you get continuity. First check the defrost heat if you get the chime sound from the meter or NOT a infinite number of Ohms then its good. Then look for the round shaped part hooked to the evap and in series to the heater this is the bimetal (while its good and cold) cut wires to it and strip ends and check for continuinty there also if so, it's good but must be frozen cold to get continuity wire nut it back after check if good. If those parts check out then your mechanical defrost timer is bad or adaptive defrost board is bad it would be either one depending on this model of fridge you have. Hope I helped.
Posted on Jan 23, 2008
barkencoa
  • 3463 Answers
SOURCE: HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Posted on Jan 04, 2009
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Posted on Mar 22, 2010
brownline45
  • 310 Answers
SOURCE: freezer seal isn't gripping properly
in that case. you may have to consult your problem to the store where you bought that freezer. so they have to fix your problem
Posted on Jun 25, 2010
  • 670 Answers
SOURCE: Hotpoint freezer, High temp light on & all food thawing
It's probably the defrost timer is getting stuck in the defrost mode. What it does it it periodically interrupts power to the compressor and sends power to the defrost coils to allow any frost on the cooling coils to melt to keep them clear of ice build up. This is typically a mechanical timer and sometimes the motor fails and it stop turning and if it fails in the defrost mode, the compressor never turns back on no matter how warm the freezer is.
You can confirm it is the timer, by tracing the wires from the compressor to a little 2 by 2 inch box which is the timer. On one side there should be a round hole with a plastic cam. You should be able to turn that cam with a flat screw driver or a coin. Just give it a slight turn until you hear a click. After you turned the cam, the compressor should start. If it does, then it is the timer.
Posted on Jul 01, 2010
Hotpoint FZA 80 Red light keeps coming on
it means there is a temperature problem. It is a warning light
Jun 04, 2014 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint freezer FZA84 does not freeze ,high temperature light is on. when switched on the temperature comes down to about -12 C . does not come any lower but i hear a irregular hissing sound probably
You need to cut it off. You may be doing a lot of damage there. If this freezer is 8-10 years old, you may want to go ahead and replace it. At least it will not give you any more problems.
Jan 25, 2013 | Hotpoint Freezers
Hi I have a Hotpoint Fridge Freezer and I have noticed that the Freezer High Temperature light keeps coming on and off.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | Hotpoint Freezers
High temperature light keeps coming on
dear sir/madam please make sure your freezer,s door all is close and watch if its light coming again then there is one componennt temretuture sensor its needle need to reset or change.
hope problem will be solve.
thank you
Jul 09, 2010 | Hotpoint Freezers
Freezer seal isn't gripping properly
Jun 21, 2010 | Freezers
RED HIGH TEMPRETURE LIGHT IS ON.WHAT IS THE USUAL
if the temperature rises above 30 degrees then this is to let you know that there is a problem.
it could be one of these problems:
dirty condender
condenser fan not running (if available)
freezer fan stop working
compressor valves bad
lost of freon (under charge)
defrost heaters not working
bi-metal t'stat not working
timer bad
if you need more help let me know
Mar 27, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
High Temperature Light
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 11, 2010 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Freezers Logo
44 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
