Speedo aquabeat no qualified device connected
4 Suggested Answers
SOURCE: speedo aquabeat not playing
have you checked the volume level to make sure that it was not lowered by mistake? Just a thought.
Posted on May 23, 2010
SOURCE: My Speedo Aquabeat is not recognized by my PC when
i had the same problem and i was told to try plugging it into another USB port on my PC and that worked. however, i was using a PC and not a laptop, not sure whether that will make a difference. good luck.
Posted on Sep 05, 2010
SOURCE: Speedo Aquabeat is not recognized by my Macbook Pro
I plugged my aquabeat into my mac. It mounted and I deleted all the files onto it. Then, I copied a bunch of mp3 files onto it. The device registered as full and wouldn't let me add any more files even though the info window said there was 250 MB available but this was wrong or misinterpreted by the device. I couldn't make it work. I found there was insufficient capacity for the operational files to be built on the device. I deleted one of the mp3 files to free up space then ejected it which caused it to be unmountable on the mac - it wouldn't turn on at all. I pressed the reset button and it all came to life and now it works as advertised. The device needs to create a bunch of work files for it to start. I believe that it really was out of space and could not create the work files. When I deleted the mp3 it freed up enough space so the work files could be created, but it was frozen. The reset caused the work files to be created and all was well.
Posted on Mar 17, 2011
I have just brought a imac computer, how do I get the program required to use my speedo aqua beat
website says the software is not compatible with mac, but it states that when you connect the device to your mac a folder should show up on the desktop and you can just drag songs into that folder
http://help.speedo.com/app/answers/detail/a_id/75/~/how-do-i-use-the-speedo-aquabeat-playlist-editor-software%3F
Aug 12, 2011 | Speedo Aquabeat MP3 Player i
Speedo MP3 pink 1 gig. When I plug into my Mac (yes, Mac hooked to power source; yes, plugged directly into the Mac's USB) I continually get a message saying I've ejected incorrectly. Then shortly...
It probably means your usb connection is loose. You can try another usb port on your mac, if that is better then the usb port you usually use is bent or has a loose connection, if not the problem is likely the MP3 player's usb.
You could try putting a small amount of weight on the MP3 Player while its plugged in to improve connection. While it is plugged in, use your finger to lightly move the device up or down and hold gently. If the connection improves, use a small weight to hold device in that spot. If you are pushing down put a small box on top of the device, if you are pushing up, gently wedge something underneath drive.
Hope this helps.
Sep 20, 2017 | Speedo Aquabeat (2 GB) MP3 Player
My aquabeat won't turn on. It charges but nothing else. What can I do?
You know that it will only work when earphones are inserted? Push the "Play" button for about 10 secs and wait for the beep.
Aug 03, 2010 | Speedo Aquabeat MP3 Player i
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Feb 19, 2010 | Speedo Aquabeat MP3 Player i
Speedo Aquabeat Orange light and won't play anything
Hi I got the same issue, you can email sales@speedoaquabeat.com and they will revert to you.
Jan 12, 2010 | Speedo 7410061 MP3 Player
Aug 22, 2009 | Speedo 7410061 MP3 Player
Speedo aquabeat not playing
Aug 01, 2009 | Speedo 7410061 MP3 Player
Aquabeat wont charge
There might be a problem with the connection. Using the player under water for long periods of time can build a sort of calcium on the connections inside the player. Look to see if the internal connection in green, if so you might want to get a really small screw drive and just scrap some of the calcium.
Jan 09, 2009 | Speedo Aquabeat MP3 Player i
 Grubhead
Grubhead
