Question about Garden
Worx WG787 mower won't start
The battery is fully charged. There is a click but the mower will not start.
4 Suggested Answers
  • 407 Answers
SOURCE: Though my Worx WG781 cordless
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
Posted on May 20, 2011
  • 214 Answers
SOURCE: my worx 24volt mower just
The battery is overheating and is shutting down as a safety measure. If allowed to continue overheating, you risk it becoming a fire hazard.
You will need to replace the battery and dispose of this one accordingly.
Posted on Aug 08, 2011
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
My Worx WG783E cordless lawnmower starts fine but stalls after 3 seconds, can anyone help me fix the problem? Thanks!
need to load test the batteries --and test amp draw to the motor look under dek and make sure no debris is caught around the blade shaft --can cause over heating of motor
Sep 18, 2016 | Cars & Trucks
How do I check a battery operated mower? It stopped working.
Have a close look at the blade. It may have jammed up with a stone or stick or something and melted the inside mounting. The blade may be spinning on the shaft and not actually be turning by the motor now.
Sep 17, 2015 | Worx Garden
Worx mower. I was mowing fine..stopped to change bag.. Wouldn't restart when pushed the key button. handle engaged and it would power move forward. Engine would not start.battery fully charged
sounds like, a valve clearance adjustment problem. starts when cold, looses some power when hot, if turned off or stops, won't restart until cold.
Aug 04, 2015 | Garden
Worx 17'' Cordless Lawn Mower (Model WG787). I've got a barely three month old lawnmower and the battery is fully charged yet the blade only barely spins. Seems to be virtually no power despite the charged...
The batteries are defective in this unit. It should be returned to the dealer that you purchased it from and get exchanged, or your money back. Another way to test this mower is to charge the batteries fully, then test them. If they are truly fully charged, run the mower until it slows down, and test the batteries again. If they are still charged, (unlikely) then the problem is in the motor itself and still should be returned.
Sep 09, 2017 | Worx 17" Cordless Lawn Mower with...
Why won't battery charge?
The battery may need replacement despite the fact that your lawn mower is essentially new. Leaving it discharged for an extended period could have caused early failure. There is another possibility and that is the charger may have failed
Jul 16, 2013 | Worx 13Amp 16Inch Electric Lawn Mower...
Worx WG787 lawn mower issue
does the blade spin freely if not bearings going out check make sure blade brake is fully releasing the blade to spin you will probably have to take it in it could be in the activation swicth but you need special tools to check it
Jun 29, 2013 | Garden
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
Garden Logo
347 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
