Question about Husqvarna 224L 4 Cyc Gas Trimmer
Husqvarna 224L choke switch will not stay at start position
My Husqvarna 224L Choke Switch is loose and will not stay in any position.
  • 246 Answers
SOURCE: Husqvarna looses power after 10-15 min.
Hello Matt:
From your Description it Sounds like Either the Gas Cap is Not Venting the Tank, the Exhaust Port/Muffler is Restricted or the Rings are Worn Out and Require Replacing.
Make Sure the Gas Cap Allows Air into the Tank.
If the Gas Cap is Good, then
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
If the Exhaust Port and Muffler are Clear, then Most likely the Rings are Worn and Require Replacing.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 198 Answers
SOURCE: my husqvarna 125L weed eater will only run with
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
Posted on May 10, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My husqvarna 125l will not
Hi chrisputten...
Try these solutions...
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 18, 2011
rycgl
  • 1545 Answers
SOURCE: Husqvarna 28cc weedeater primed x3...choked
This sounds like a fuel starvation problem. These units use temperamental little diaphragm carburetors which can develop assorted ills and problems. Sometimes, the problems stems from debris in the carb, fuel tank, fuel filter, or inside the carb where there is another very fine filter. You have stated that it runs 30 seconds, but I don't know if it is IDLING for that period or running at speed for that period. At any rate, check the in-tank fuel filter, ALL fuel lines, and if you can remove the fuel pump cover on the carb (it does NOT have a vent-hole), and check inside where the little round fine wire mesh screen is. Check it for debris.
If all the above are OK, then the carb may just require a small adjustment. The problem here being the type of screws used to adjust the Low and High speed mixtures on the carb. Some have splined heads, some have Pac-Man shaped heads, some have D shaped heads, and some have Double D shaped heads. Older ones have conventional slotted screw heads. On the non-conventional ones, you can use automotive type wire terminal spade connectors. Before you put them on though, you need to note the exact position of the mixture screw you are going to adjust. After that, tap the connector onto the head of the screw. If you use a female spade connector (22 gauge or so), then the end of a small flat blade screwdriver will fit the spade and you can turn the screw. I will refer you to an excellent Zama (probably your carb) carburetor adjusting tutorial now.
http://www.zamacarb.com/tipspage.html
Try these things and feel free to post back. We will continue to try to help with your issue.
Posted on Aug 06, 2011
  • 2210 Answers
SOURCE: My Husqvarna 128ld trimmer will run but only at
guys,
the d shaped tool is also carried as an MTD part. see your local dealer.
If not google walbro d cut tool ad see what you get. They're on solo
chainsaws as well
Posted on Dec 03, 2011
Husqvarna 324L has a floppy choke. What should I do?
To properly repair,, it may require a carburetor replacement. To my knowledge individual parts for the carb is not available.
Jun 25, 2017 | Husqvarna Garden
Husqvarna 236 brand new will not start
1. Make sure you have used the correct fuel to oil mix in the tank.
2. Set on/off switch to ON position.
3. Pull out the choke switch to (full choke position)
4. Prime the carb by pumping the primer bulb on the carb until fuel fills the bulb.
5. Pull over saw until the saw fires.
6. Push in the choke switch.
7. Pull over and the saw should start.
May 09, 2013 | Husqvarna Garden
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.
Lock throttle trigger on,
Start on full choke till it fires,
Switch to half choke and it should fire up on high revs,
Blip the throttle and it should turn to tick over.
If it still keeps cutting out it could point to a carb or fuel takn issue.
Aug 04, 2012 | Husqvarna 223L
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
I have a husqvarna 450 that won't stay running and has oil coming out the excaust
It sounds well flooded, remove the spark plug, with the kill switch to off, crank the engine five or six times to evacuate any excess fuel in the cylinder, leave the machine for an hour or so, re fit the plug and attempt starting with no choke.
May 30, 2011 | Husqvarna 450 e-series 18" Chain Saw
New Husqvarna 30 cc 2Cucle Gas Backpack Leaf Blower Can not get it to start. Need starting instructions.
Turn the switch to on, push the primer bolb about 8 times to get the fuel up to the carburetor, put the throttle about 1 quarter to a half way up, put the choke on closed and it sohould start. When it sputters open the choke slightly. Let it warm up and open the choke completely.
Mar 19, 2011 | Husqvarna Garden
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
I have a husqvarna 36 chainsaw that starts and runs just fine. However, the stop switch doesnt seem to work. I push the switch to stop and the saw continues to run. The only way to kill it is to use the...
Hi
Yeah,your switch has gone bad,and using the choke isn't how you want to kill it for too long.Fouled Plugs.Here's a link to the service manual pdf if you want to do it yourself. Shouldn't be too hard.
Please rate my post?
Bob
http://www.airtimeproducts.com.au/assets/docs/Husqvarna%20service%20Manual.pdf
Aug 13, 2010 | Husqvarna Garden
Brand new husqvarna chainsaw won't start
A commen problem is flooding the engine.
A good way to start it is to press the fuel pump balloon three times choke it. pull once...pust the choke back in so that its stops choking and give it a few swings then it should start.
i am asuming you have put the on of switch to on.
Jul 11, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 224L 4 Cyc Gas Trimmer Logo
29 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
