Get error: Oxc000021a when booting windows 8
HELP??? can' boot up my PC. get a blue screen with error: 0xc000021a says to restart PC, but can't. when I push the on button get the same thing...
5 Suggested Answers
  • 1170 Answers
SOURCE: Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Posted on Apr 01, 2009
  • 11 Answers
SOURCE: M1400 Tablet-PC doesn't boot
get a hirens boot disk. that will fix ya right up. boot from the disk. choose either option boot windows xp mini or from boot disk. do not choose the option boot from hard drive or you will get no-where.
Posted on Jul 15, 2009
SOURCE: when booting screen is split into 4 part after blue error screen
Is your vga driver related issue.
When you power up the computer press F8 key continue thene nter in safemode.
Then right click on my computer then click on proeprty then go to hardware device manager then uninstall graphic driver.
Then restart the computer then install the correct driver.
Also you can enter in enable vga mode then open control panel ->dispaly proeprty then settings change screen resolution to 1024*768 then apply and ok.
then check.
Let me know if you need more assistanse.
Thanks.
Posted on Aug 31, 2009
parrotheadpc
  • 2600 Answers
SOURCE: ibm thinkpad r50 notebook won't boot
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 15, 2009
How can fix this error to be able to boot my laptop?
Do you have the install media? If no can you boot into safe mode?
Jul 26, 2016 | Acer Computers & Internet
How do I correct the problem code C 0000001 on Windows 8 operating system
Solve Error Code 0xc0000001 in Winodws 8 Team Windows 8
Windows 8 Blue Screen of Death (BSOD) or Error Code: 0xc0000001 sometime occurs without any specific issue. You can't be sure what actually caused it. Be it a system issue or some driver problem, you may end up seeing this screen when you restart your computer.
To solve this blue screen error in windows 8, turn off your computer and when you power it up again, immediately press SHIFT + F8 key you will be resented with following screen:
Click on "See advanced repair options" and from the next screen, choose "Troubleshoot":
On the next screen, choose "Advanced Options"
In Advanced Options, choose "Windows Startup Settings"
There you will find a button "Restart". Click on this button and allow the wizard to complete all the steps. Note that it will repair your computer without making any changes to it. Once the process is completed, your computer will automatically restart and you should be able to boot windows now.
Still facing same error?
If you have followed all the above mentioned steps but got no luck in booting up your windows then probably your cause of the error is more solid and cannot be restored with mere settings reset. But don't worry, it can still be solved using windows recovery options. For this you should have a recovery/installation disc or USB Flash Drive.
Windows 8 Recovery Guide Recover When Windows 8 Fails to Boot Team Windows...
Jul 07, 2015 | Computers & Internet
Fix error oxc000021a on a acer aspire 5600u touch screen computer
Have you access to the CMD prompt ?
If yes, maybe we can solve the problem.
If not, you have to reinstall your computer, booting on the optical drive (CD/DVD). Be aware, doing so will ERASE ALL YOUR DATA.
Dec 04, 2014 | Acer Aspire 5600U all-in-one desktop
Why my hp desktop keep turning off error c000021a
this is how to fix your desk top with xp,if you have another os,this may also work,but,be prepared,you may need to reinstall your os,if this works,then immediately download this and run it, SpeedyPC Pro Download ,and then d/l this and buy it to keep your pc running great,http://www.iobit.com/advancedsystemcareper.html , Things You'll Need
  • Windows XP installation CD
Instructions
  1. Last Known Good Configuration
    • 1Restart your HP computer after the blue screen shuts it down.
    • 2 Repeatedly tap "F8" when the HP logo screen appears during bootup. This will load a menu with various boot options to select.
    • 3 Use the arrow keys to select "Last Known Good Configuration" and press "Enter." The system will roll back recent changes and may fix the problem. Continue to the next step if the computer does not successfully boot.
    In Place Upgrade
    • 4 Insert the Windows XP installation CD into your HP computer's disc drive.
    • 5 Restart the computer.
    • 6 Press any key on your keyboard when you see "Press any key to boot from CD..." This will launch the Windows Setup program.
    • 7 Press "Enter" to begin the installation process.
    • 8 Press "F8" to agree to the Windows XP licensing agreement.
    • 9 Highlight your current installation of Windows XP and press "R" to perform a repair installation.
    • 10 Follow the onscreen instructions to complete the repair installation. Your personal data and applications will remain intact, but all Windows updates and service packs will be removed during this process.
Tips & Warnings
  • Back up your data before running a repair installation on your HP computer.
Related Searches
eHow Now Ask online tech support online now Ask online tech support - get your answers in real time!
Get Your Answer
References
  • Photo Credit laptop with blue screen image by dim@dim from Fotolia.com
SpeedyPC Pro Download Advanced SystemCare Free 7 6 5 4 3 Download Review for Windows XP Vista...
May 21, 2014 | HP Computers & Internet
Dell windows 8 laptops
The BAD_SYSTEM_CONFIG_INFO ERROR occurs when your system is corrupt
so restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.and select "last known good configuration" in the boot options.
If this didn't resolve your error then simple get the Reginout to fix all the registry issues and errors which causing this annoying message
Jun 27, 2013 | Dell Inspiron N5030 Notebook PC
I installed my antivirus program the other night. When I rebooted the computer it booted up, went to home screen, then went to blue screen. I tried reinstalling Windows from the disc and it worked for a...
it's more than likely a driver issue, as the computer boots tap the f8 key and you'll presented with a boot menu. load the system in safe mode and see if it loads properly. if it does, uninstall the video drivers (usually the culprit) and then load the drivers from the manufacturer's website. windows update drivers sometimes screw things up more than they help. you can also tap the f8 key at boot and toggle down to 'do not restart on system failure' and restart. when the pc boots and it blue screens again it will stay on the screen and you can get the failure hex code. that will help us diagnose it
Aug 01, 2012 | Computers & Internet
I frequently have windows blue screen problem. at 1st i go back to Acer service center for repair. They have reformat my PC with Windows Vista. few months later, i have it again and i restore it with my...
PowerSuite Golden is the right software you need in your case, it is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Download the ISO file----> Burn it to CD----> Boot your PC from the CD by setting the CD drive as the first boot device in the boot sequence.
Jun 04, 2011 | Acer Aspire m5640 PC Desktop
Can't reboot starts out li9ke noremal trhen a very quick blue screen and i have to restart the boot process all over againj
I came across this kind of situaiton on my HP laptop (win 7) and ended up with eliminating it with a boot program called BuitSuite and it helped entered my Windows and resolved the program. It seems that there is a system file missing which lead to error loading error when you boot. Hope it will also help in your case, best regards.
May 22, 2011 | HP Compaq nx9010
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
1,464 people viewed this question
David Payne
David Payne
