Question about Dishwashers
DIM1524W water box is not filling all the way
Water box fills but shuts off before it fills all the way. Keep getting the flashing FAULT sign.
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#4#ixzz2a20kdgob
Posted on Jul 25, 2013
Testimonial: "I do apologize, the water box I was refering to was for the Danby Designer Ice N Easy portable Ice maker Model DIM1524W. It turns the water off before the box get full enough to start making cubes."
  • 74 Answers
SOURCE: Dishwasher doesn't stor filling
If the dishwasher's water flow doesn't automatically shut off, the float switch is faulty or the timer is stuck on "Fill" or the water inlet valve is stuck open. To test the float switch, you'll need an inexpensive volt-ohm meter (or multi-tester). 1) Unplug the dishwasher. 2) Reach into the cabinet and lift the dome-shaped plastic float switch. If it doesn't lift, remove the plastic top from the stem, scrub the stem clean, and then replace the dome. If it moves up and down freely, go on to step 3. 3) Note which wires are attached to the float switch's terminals and, using small pieces of tape, label them for later reference. 4) Set the volt-ohm meter's dial to Rx100 and touch the two probes to the terminals. When you lift the float, the tester's needle should show an infinity reading and, when you let the float drop, the needle should show 0. If it doesn't, the switch is broken and will need replacement. Unscrew it from the tub and replace it.
Posted on Jan 18, 2006
  • 131 Answers
SOURCE: Bosch shu9905
Check the drain pump. First, manually initiate drain by pressing the second and fourth buttons on the keypad at the same time. If it pumps out, disregard the rest. If it doesn't at least hum, check for power at the motor.
Remove lower rack, lower spray arm, and screens in bottom, remove all water inside. Check for debris under pump cover in bottom of sump. The drain pump suction is through the hole on the left.
Behind the toe panel on the left is the drain motor, If no debris was found inside, the drain pump may have failed. Remove outer door panel (you may need to remove the two screws on the sides of the control panel.) Remove the metal panel across the top of the motor area , disconnect hose in front of pump, disconnect wires to pump, press tab at top of pump and rotate clockwise to remove pump. The impeller could be loose on the motor shaft, or the motor windings failed.
Posted on Mar 10, 2008
osborne382
  • 306 Answers
SOURCE: Blanco Dishwasher BIDW605 does not
I would check the hose/water filters. make sure that you have proper flow from the hoses
Posted on Apr 04, 2008
  • 4 Answers
SOURCE: Machine does not fill with water
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed. Failing that check the water pressure to the unit!
Posted on Apr 24, 2008
SOURCE: Heller DWH16 slimline dishwasher not
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Posted on Nov 11, 2008
Danby ice maker service manual
I took mine apart today and found the plastic armature that the motor connects to in order to turn the water tray right side up and up-side down was broken. Essentually the water tray has a plastic pivot arm on both sides. The one side has a slot that the motor fits into which allows the motor to turn the tray. When that little plastic arm breaks, the motor will be unable to move the tray thus causing the fault symbol. I have my tray out and trying to fabricate a part that will hopefully last a lot longer than the original. I hope this helps someone with their issue.
May 16, 2012 | Refrigerators
Fault h20 flashing will not fill with water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 21, 2011 | Washing Machines
I hav e code H and a code F flashing on my whirlpool front loading washing machine what does that mean. It has stopped in mid cycle.
it means a water fill error,either the units not getting water or the pressure fill switch in the top right side of the unit isn't detecting water level and shutting off the machine after a preset amount of time,find the diagnostic troubleshooting pamphlet inside the unit and run the diagnostics on the machine and it will tell you what components at fault
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
GWL15 starts to fill, water shuts off & water coming in slows to a trickle. Hot & Cold lights flash, machine beeps. If filled with buckets of water cycle will finish.
A common fault with F&P machines is in the water inlet valves.It is not afvisable to exchange the hot and cold valves because they are different. The faulty valve should be replaced. . Goodluck.....Nomess
Apr 23, 2010 | Fisher Paykel EcoSmart GWL15
Machine will not fill the door locked sign
Sounds like could be fill solonoid valve faulty or water turned off..
Jan 23, 2010 | Hotpoint WMA54 Front Load Washer
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
Fills with water when not in use.
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Doesnt agitate and there is a gronding noise during wash and spin
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Nov 14, 2008 | Maytag PAV2300 Top Load Washer
Water level switch doesn't shut off the water
Washer Basics: Filling with water:
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
