Question about Sram Red
Slow and tight Sram red Crank
Hi! I just got my pinarello dogma frame and i'm trying to put on a sram red group. I use the Sram GXP but when i tighten the crankbolts the crank won't rotate at all. It might seem like i'm missing som spacers between the driveside crank and the bottom bracket but i have checked the manual and all the videos i can find on youtube, but I can't seem to figure out whats wrong. Please help me.
  • Sram Master
  • 980 Answers
I'm sorry, but if you don't know how to order the correct BB or properly install it you should not be building a bike from scratch, as this is probably the first of many problems you will have. As for YouTube it's not a reliable source of technical info. Try this site: http://www.parktool.com/blog/repair-help
OR Contact the frame seller and find out what BB the frame takes or contact the seller of the BB and ask for assistance.
Posted on Jul 28, 2017
  • 37 Answers
SOURCE: replacing Attack's rear derailleur cable
Stop everything! Do not take the shifter apart! Go to the rear derailleur and look where the cable is attached. There is a bolt with an allen key head, it is an 8mm. Losen off the bolt. REFER TO PARKTOOL.COM
Posted on May 26, 2009
  • 1137 Answers
SOURCE: SRAM FORCE crank lock
If it won't pedal you probably have a broken bottom bracket. This needs to be done in a bicycle repair shop as you need the right tools to disassemble it.You will also need the exact replacement parts as they come packaged with the kit and diagrams for installation. Sorry I'm not more help.
Posted on Jun 05, 2009
richard191
  • 691 Answers
SOURCE: just installed sram pc991 with shimano xt goupset. the chain
Hello
Thank you for using
FixYa for your problem
You have replaced front and rear chain rings too
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 26, 2009
  • 16 Answers
SOURCE: on my ROAD bike could a Sram/Truvati XX or XO
To use Sram Red Shifters with such a wide range rear cassette requires a Sram 10-speed MTB rear derailleur such as an XX or X.0, it will work without problems with your red shifter.
Because it is a road bike, i suggest leaving the road crankset and front derailleur in place. If you need low gearing I suggest a compact front crankset.
If you need to use a mtb crankset, attept to use the road front derailluer with it.
Posted on Mar 16, 2011
dunnbiker
  • 8546 Answers
SOURCE: My 7 speed sram rear
http://www.parktool.com/blog/repair-help/shift-levers-shifters
or
http://www.sram.com/en/service/avid/view.php?catID=1&subcatID=3
http://www.sram.com/sram/mountain/category/80
or contact them and ask.
Posted on May 08, 2011
What is the serial numberof Original Pinarello Dogma 65.
On every device is an unique serial number. So nobody even can guess what number was on yours.
Jan 16, 2015 | Cars & Trucks
Tip
GXP Integrated Bottom Bracket Adapter
Follow this link and see how to use <span>GXP Integrated Bottom Bracket Adapter</b></span> <span><a href="http://www.sram.com/_media/techdocs/GXP%20Integrated%20Bottom%20Bracket%20Adapter%20Rev%20C.pdf">http://www.sram.com/_media/techdocs/GXP%20Integrated%20Bottom%20Bracket%20Adapter%20Rev%20C.pdf</a></b></span>
on Mar 01, 2011 | Cycling
The front derailer on my sram red compact just wont change quick!
Which brand of shifters are you using? A SRAM derailleur won't work with Shimano shifters and vice-versa.
So - first; if you are using SRAM shifters with the Red derailleur - then changing to Shimano will not solve your issue but only make it worse.
If however you have Shimano shifters - then this is a good solution.
The Red derailleur should not shift that poorly with SRAM shifters. It is not the best - but it's not bad. If I had the bike in a repair stand I would be looking carefully at the following after affirming that the shifting system was indeed all SRAM:
  • Derailleur cage height relative to the large chanring - should be a maximum of 2 mm
  • Derailleur cage should be aligned as close to parallel to the rings as possible
  • Derailleur upper and lower limit screws should be adjusted within spec and in order to allow the derailleur to travel the correct amount for ideal shifting
  • Derailleur cable tension should be correct.
Hope this helps... Let me know if you need more.
Oct 28, 2012 | Sram Red
On my ROAD bike could a Sram/Truvati XX or XO (crankset 42/28-cassette11/36) work smoothly with Sram red doubletap Thank you.
Mar 11, 2011 | Sram X-0 XO REAR DERAILLEUR MTB ATB LONG...
Sram Red outer chain ring problems. I have been a bicycle mech since 1994. I have a customer with sram red chain rings. He was in outer ring 53T and smallest cog rear cassette. The outer chain ring folded...
im in the industry aswell hmmmmm never heard of any recalls but i know quality speaks volumes of whether i would buy product from which i see an obvious quality based failures ive has similar issues and reported them sram said abuse without even looking at the issue we since have discontinued their line of products hope this helps
Nov 16, 2010 | Sram Force Crankset 53/39
Jun 04, 2009 | Sram Force Crankset 53/39
Sram Red Logo
99 people viewed this question
Top Sram Cycling Experts
hgpilot
John Egan
John Egan
Mike
Are you a Sram Cycling Expert? Answer questions, earn points and help others
