Kenmore 970 c45192-00
How do I clean out the pump?
2 Suggested Answers
goodwinpeg
  • 744 Answers
SOURCE: how can i fix it when kenmore type JD21, model 970-432603 refrigerator not cold but freezer is cold
Hello Mhoo;
My name is Peter. I am a retired field service refrigeration technician.
The model number that you have provided is the general manual number for several models. Your model number is located on a label in your fresh food section, on the side wall near the top.
You have a simple top mount freezer. These are the best because they are reliable and easy to repair.
I need you to send me your model number so I can better help you.
So, in general, you only have one cooling source and that is your freezer coil.
1.) Air Vent - There is a air vent from your freezer to your fresh food section. It is located at the back top of your fresh food section. Put you hand in front of this vent. Do you feel any cooling air flow? Probably not.
2.) Ice in Vent - Look into the freezer section where the vent goes from the freezer to the fresh food section. Is it plugged with Ice? If so use a hair dryer to clear the vent.
3.) In your fresh food section you may have a auto motor driven air vent. The motor in this vent assembly may be bad or the temperature sensor controlling the air vent motor may be bad.
4.) In your freezer - Is the fan running?
Get back to me with your model number and if need be call me.
You can fix this yourself. I have faith in you.
Peter
Glen Burnie, MD
443-306-1362
Posted on Jan 24, 2015
My kenmore 970-38712 washer makes a terriible banging noise on the final spin.
http://www.searspartsdirect.com/model-number/9703871220/0582/0153200.html?searchType=modelSearch&q=970-38712&searchTerm=970-38712
This link shows you your tub parts. There are 2 springs and 2 shock absorbers. Those may be bad broken or loose and one other thing to check is make sure the inside drum has not broken off of the spider assembly in the back. An easy way to check that is open the door and grab the front lip of the metal tub and try to move it up and down, you will notice a huge amount of movement if it is broken loose. The videos I posted apply to all front load washers, The first 2 are great on diagnosing and the last one shows whats left of a broken spider gear. Kenmore Washing Machine Model 970 3871220 9703871220 970 3871220 Parts
If it is the spider support assembly then you will have to replace the entire inner tub and that is about $400 just in parts.
Jan 14, 2017 | Kenmore Washing Machines
I need a manual kenmore slide in range electric 90152
I don't believe that is the actual model #. Pull out the drawer and look for a sticker on the frame of the stove. Also open the oven door and look for a sticker on the frame there. If its a Kenmore the sticker should have something similar to "970-", "956-", "110.", "646-". Take the full model number and Google it. If its a "970-" you should be able to find the manual here: http://b2b.frigidaire.com/support/manuals.asp
Apr 12, 2014 | Kenmore 90154 / 90152 Electric Kitchen...
Kenmore freezer,model # 970-155320
How much cold can this kenmore 970-155320 be,it need to be....
  • A freezer that is at or below 00F (-18oC) i wanna use it for bed bug killing.....
Jan 04, 2014 | Kenmore Freezers
My kenmore washer 970-C47092-10 after pressing start button ERR appears and does not spin
hello check the pump it has to drain before it spins also the filter if it has 1 hope it helps
regards
shaun
Apr 03, 2011 | Kenmore Washing Machines
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Will not pump Kenmore model 970-c45072-00, purchased in 2005
Pump blocked probably something stopping it, sock, coin etc
Mar 13, 2009 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
