Question about Kyocera FSC5150DN Laser Printer
Error code call service F000
2 Suggested Answers
SOURCE: Call Service F000 error
F000 is a panel communication error... update firmware... firmware as far as i know isnt available to the public... contact kyocera
Posted on Jan 15, 2009
Hi Fixya,can you please help us how to fix kyocera taskalfa 1800 call service f000
Heat code. You will need to reset in service mode.1087 1087 function find reset fixing assembly and activate. If it comes back you have a bad bulb or a bad thermistor. Could be a thermal switch . It's the fuser assembly.
Feb 12, 2017 | Kyocera Office Equipment & Supplies
Receiving error code C-E301
I just found this on the knowledge base it refers to this code when the hdd is replaced and internal data is different it may be a faulty hdd but there is a firmware in reference to this code.
Error C-E301 occurs for mismatching in the internal data as HDD is changed.
C-ED01 will be displayed as the mismatch in the internal data occurs as HDD is changed.
HDD Format will be necessary when this trouble is displayed.
firmware: A2X00Y0-F000-GPQ-65.exe
Mar 31, 2014 | Konica Minolta Bizhub C454 Color Copier
Hotpoint w640 F000 error code
see this mean :Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Read more: http://www.appliancepartspros.com/repair-help/hotpoint-fault-codes.html#ixzz2gUdlkOnE
Oct 01, 2013 | Hotpoint Aquarius WD640 Front Load...
Ho heat when drying cycly all else is ok. faolt code is f000
see the error mean:God bless you
I/0 card parity interrupt at F000:E1AD. Type (S)hut off NMI, (R)eboot, other keys to continue
This error refers to an expansion card having an issue. If you've got any cardbus, wifi, bluetooth, etc cards take them out and see if that resolves the issue. More info here:
http://www.techsupportforum.com/forums/f217/i-o-card-parity-interrupt-at-f000-e1ad-417586.html
Jun 05, 2012 | Dell Inspiron™ E1505 PC Notebook
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Machine failure call service f000
Idea: You can look up the failure codes online in the Kyocera website. Just download the maintenence manual.
Feb 10, 2011 | Kyocera FS-C5030N Led Printer
Error code on booting
it may be a memory board error.. you may have to replace the motherboard
Sep 16, 2008 | IBM NetVista PC Desktop
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FSC5150DN Laser Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
