Transcend mp870 player stopped working
My mp870 transcend is freezing whenever i enter into the internal memory. What should i do??
I have MP870 and the same problem.
Going to the "Settings > Format Internal Memory", solved my problem.
Good Luck :)
Feb 13, 2015 | Transcend Tsonic 870 MP3 Player
I have a transcend mp870. Recently it has stopped sending the audio signal to an external device like my stereo or even headphones. The sound continues to play through the little in-built speaker in the...
Have you checked the ports and all connections? If any wires are bare, insulation exposing wires, water or oil making contact with the in/out lines and ports; this can cause a short. If any of the transistors on the circuit board have degraded the sound will diminish greatly. Age related conditions can occur, if capacitors or diodes are no longer capable of doing their job. There are many reasons for this to happen, and in most cases, a replacement unit is less costly than repairs.
Mar 05, 2014 | Audio Players & Recorders
My transcend mp870 was hanged,what should i do?
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Nov 15, 2013 | Electronics - Others
Transcend MP870 it is always getting hang while charging
at the command prompt type chkdsk x: /f /r where x is the flashdrive.
Sep 23, 2013 | Electronics - Others
I want to download MP870 user manual
http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&ItemID=TS8GMP870&axn=SRH1_RLT&DLKeyWd=mp870
Apr 18, 2011 | Audio Players & Recorders
When I try to put a converted youtube video from MP4 to an AVI on this player it tells me its in an invalid format. I have 2 players one for music and one for videos. I can't remember how I did it last...
Make sure which formats the player supports. Avi is just the container and can have many formats . According to the specs the player supports wmv,avi and flv try converting the videos again but use a resolution of 220x176, it might help as the player would not have to scale the video down. I have also noticed that the transcend player MP860 had it's own converter software. Check if your friends have the MP860 or MP870 player and install the software off the cd and try converting the video files as the coby may support the same format.
Jan 16, 2011 | Coby MP-705 Digital Media Player
Mp3 player not getting formated
Hey never format your player,there is a hidden file and it will stop working after formating.Go and check out in the service centre for this problem.
Apr 16, 2008 | Transcend T.sonic 610 MP3 Player
Transcend tsonic player problem
initializing and not proceeding...please help...for most users same problems...please clear this doubt,,,
Mar 25, 2008 | Transcend T.sonic 610 MP3 Player
 Grubhead
Grubhead
