Question about MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard
Windows Setup cant find hard disk ?????????????
Hia im stuck realy stuck and probberbly to my own fault heres the story i have a MSI K7n2 Delta L/ilsr barton 2.8+ ATI X700 agp Maxtor 80gb Sata hard drive cd/dvd & floppy ok so im trying to install windows XP back on my sata drive problem being at the moment Ubuntu Fietsy Fawn + Beryl is on it and refuses to move!! wht have i tryed? 1) i put the xp disk in and booted setup got my sata driver floppy disk out and pushed f6 selected them 1 at a time to instal hit enter and it said cant find hard drives 2) i put the xp disk in and booted setup got my sata driver floppy disk out and pushed f6 selected them both together for instal hit enter and it said cant find hard drives 3) found out somthing about GRUB and it writing a code on the hard drive so i tryed to boot off a dos disk and typed the old fixmbr and the old Fdisk but still to no avail just said not found blarr blarr blarr 4) put in the ubuntu setup disk and tryed letting it format the hard drive in its partishon bit then harshly switching it off at the plug when it got tht far and still it didnt get rid of the thing so here i am there is a new hard drive on its way sata again but im wondering if anyone knows anything about how to make this hard drive work on windows again THANKS TO ANNYONE WHO CAN HELP XXXXXXXXXXXXXXXXXXXXXXXXXXX Boomshanka
Re: Windows Setup cant find hard disk ?????????????
My hard disk is not working so what can i do
Posted on Oct 19, 2008
  • 74 Answers
Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
Posted on Aug 30, 2007
0 characters
3 Points
Bios reset on ms 6570 k7n2 delta ilsr with jumper
Hi, you can download a manual here:
Unzip the file before you can read it.
The bios can also be resetet by removing the cmos battery:
The manual shows how to do it with the jumper settings.
Sep 25, 2011 | MSI K7N2 (MS-6570) Motherboard
Hi , my motherboard is k7n2 delta 2 platinum ms-6570e , i've had a problem to install windows xp , but finally i did it . Now i've got problem to install some programs like office , nero itp....
Hi, you can download the drivers manualy from here:
The drivers or the bios file needs to be unziped before installation.
Install first the system and chipset drivers.
Try also to run windows update.
You will need the updates to install office and etc.
Try also to add more memory ( ram ) to your system.
Supports DDR200/266/333/400
Aug 24, 2011 | MSI K7N2 Delta2 Platinum Motherboard
Hi, From where can I download a manual for the MSI-649T Pro VER 5 ?
Click here to download the Manual for MSI K7N2 Delta-ILSR from MSI Official Support
Dont forget to appreciate the solution if I could have been of any help!
Dec 06, 2010 | MSI K7N2 Delta-ILSR Motherboard
I need a manual for my motherboard can u help me find one
Try this link
I hope it helps!!!
Nov 30, 2008 | MSI K7N2 Delta-L Socket A/nForce2/FSB...
Try this link
I hope it helps!!!
Nov 17, 2008 | MSI K7N2 Delta2 400FB nForce2 Ultra...
K7 mainboard
Here's where you can download all of the drivers for your motherboard in one place, from the Vendors site:
or here:
If you load all of these drivers and the problem persists, it may be a configuration problem instead of a driver issue. Let us know.
Feb 22, 2008 | MSI K7N2 Delta-ILSR (MS-6570-030)...
unplug you hard disk, then switch on without your hard disk let your xpcd in your cd rom to run after reading your cd ''saying, no hard drive found'' switch off then plug it in your installation will proceed
Nov 27, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Intsall windows
if you can try using that same HD in another comp setting it as a slave, if you still have problems like its not being detected then there you go
MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard Logo
281 people viewed this question
Top MSI Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a MSI Motherboard Expert? Answer questions, earn points and help others
