Question about Goodman Heating & Cooling
Keeps freezing We installed a brand new Goodman Condensing Unit, Model #GSX130481, Serial #1304691511 and installed a new coil, Model #96-8W4N-0p/96-8, Serial #M0425130485 (Mortex Brand)in the existing Air Handler. The unit keeps freezing up. Can you give any insight on what might be the problem?
    Genius:
  • Goodman Master
  • 1,363 Answers
Low air flow or low on refrigerant.
Posted on Aug 12, 2015
4 Suggested Answers
  • 66 Answers
SOURCE: five year old goodman unit compressor gone bad.
Depends on if your going to stay with the old refrigerent system of R 22 ro upgrade to the new R410A system. I have been upgreading my customers to 410A if the compressor has failed. Replacement of all components recomended on a compressor burn out.
Greg. B
Sunsetmechanical
Posted on Jun 30, 2009
  • 1033 Answers
SOURCE: I replaced a comfort air hander with a Goodman air handler with a 4-ton coil.
Hello, here is a link to a chart with piston sizes http://www.acwholesalers.com/v/vspfiles/assets/images/gsc1314_piston.pdf
Posted on Dec 02, 2011
SOURCE: hello, my HVAC is constantly
I'm new at this and I can't tell how old the post is but I'll contribute anyway.
You probably have fixed the problem by now. I wonder what part of the system is freezing up. I don't have a lot of experience but I know you can get frost where there is a restriction in the freon. If the freon line filter near the outside unit has frost on the house side the filter is partially plugged. I have also seen fost on the evaporator (attic "A" coil) when there is a shortage of return air flow. You could have a plugged filter or colapsed return duct, or even an "A" coil with a lot of dust covering and plugging the fins. I guess restrictions in your room air supply registers could cause the problem too. Maybe you have most of the vents closed off to save energy. Just some possibilities.
Posted on Oct 31, 2012
Goodmans troubleshooting
Hi;
You don't mention the fan. It is at the top of the condensing unit and should be running whenever the compressor is running. The water is doing the same ob the fan does, removing the heat from the refrigerant . What led you to put water on it?
Jul 30, 2014 | Goodman Manufacturing Goodman GSX130481...
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Hello, my HVAC is constantly freezing, even after freon is added. I was told that I have a leak in the coils and need to chance the air handler - the outside unit is about 10 years old - air handler about...
No you can not use a R-410 air handler with a R-22 condenser unit...the exspansion devices are different as the properties of the refrigerants are enough different that they are not interchangable...
Really your only choice is to replace the whole unit as it sounds like the exspansion valve or the orfice is partially clogged and it makes you constantly freeze up....
There are some things you could do to make it work at reduced capacity but it is way beyond what I could tell you through a computer...
heatman101
Sep 08, 2010 | Goodman CKL42AR42 Air Conditioner
Every 1 minute it has a one second surge
Hello Dave,
The first place to start is with the line voltage supplying the condensing unit. Check ALL line voltage connections at the condensing unit, the service disconnect, and the electrical panel box. If you have a weak connection or overheating circuit breaker, it could create these surges.
Don't forget to ensure the filters and coils are clean to keep your system operating at peak performance & efficiency. :-)
May 27, 2010 | Goodman CLJ42AR49 Air Conditioner
I have a Goodman condensing unit that freezes up occasionally during low ambient weather (20 F). Model # ssz160361ac with matching new air handler. I have adjusted the defrost time from 90 to 30min. This...
It is not freezing up because of the temperature, but because of ice being formed in inside. Either by a blocked condensation duct, or snow due to previous storm.
Jan 31, 2010 | Goodman Heating & Cooling
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
What do I do when my A-coil goes out in my Goodman condensing unit? How do you replace it?
You have to be certified in refrigeration. Its a sealed system and you need the correct tools to fix. I'm sorry but you will need a tech to fix that.
Jun 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman a/c not cooling
It looks like you did make some improvements when you replaced the coil and metering devise. The fact that this system never ran right "out of the box" is suspicious. My first instinct is that the system is either unmatched in size or the whole system is sized incorrectly. Do your Heat gain/Loss calcs and see if it matches close to what is in there, both for the coil and condenser. Secondly double check that the evap you installed is matched the same as the condenser. In some situations the ID coil can be over sized by a 1/2 ton. But that is the only exception and it does not apply to all cases.
If the system is sized and matched correctly, then I would consider the compressor to be the problem.
Jun 28, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
