Question about Bikemaster 1981-1983 Yamaha Xj750r Seca Motorcycle Clutch Lever Black
Hwo many quarts of oil in a 1982 xj750r - Bikemaster 1981-1983 Yamaha Xj750r Seca Motorcycle Clutch Lever Black
How much oil and what kind 1982 yamaha vision
It will take about 2 quarts. Don't you have a owners manual with your motorcycle?
Drain the oil, replace the plug, add one quart. check the dip stick, slowly continue to fill until you get to the proper level as indicated on the dip stick.
If you have not made friends with the guy or gal at the Yamaha Parts Department, you should go do that now. They will be a great source of information to you in the future.
Find and use your owners manual.
Thanks for your interest in FixYa.com
Feb 28, 2013 | 1982 Yamaha XZ 550
What is 1982 sportster primary gear oil capacity
Hi Anonymous, 24 oz. HD Primary Sport Lube. Have nice day.
Jun 20, 2012 | Harley Davidson Motorcycles
I need to put my carburetor back on my yamaha xj750r
use a hair dryer to heat up plastic parts and a little oil and parts will slide right on.
Jun 05, 2012 | 1982 Yamaha XJ 650
Yahaha motorcycle, 1982, 650cc, wet clutch. What type of oil should one use?
To change your oil you will need 4 quarts of oil, a filter, and a new aluminum drain plug washer. You can reuse the old drain plug washer if it has not been squished out of shape. Your motorcycle comes from Honda usually with 10w-40 mineral base motorcycle oil. You can use any oil that is JASO MA certified motorcycle oil. 10w-40 for cold climate. 20w-50 for warm climate/touring. Car oils use different additives and may cause scoring in certain types of cam bearings. Do not use any oil that says " Energy Conserving " on the label . It will shorten the life of your wet clutch and transmission gears. If you choose Synthetic oils, they will help your bike run cooler and shift easier. Pour in four quarts of oil to reach the high mark on the dip stick or inspection window. Make sure the motorcycle is upright or on the center stand when checking the level . You will probably need between 3.1 and 3.4 quarts to hit the high mark. Run the motor for a minute or two to fill the up the oil filter compartment with oil. Now recheck the oil level and top up as needed. If you want to try an inexpensive full synthetic oil that is JASO MA rated 15w-40 Shell Rotella T Synthetic fits the bill at about $22 per gallon. All brands/manufacturers make a motorcycle oil. Some are very hard to find. Just make sure that the oil you pick has the JASO MA Japanese engine Rating to protect your motorcycle engine.
Jul 13, 2011 | 1982 Yamaha XJ 650
I need to know what kind and how much oil a 1982 honda cx 500 custom takes
10W-40, 2.8 quarts from draining, 3.6 quarts if you disassembled the engine.
Found at this link:
http://www.rhuss.cncfamily.com/1982_gl500.htm#specs
Apr 10, 2011 | 1982 Honda CX 500 B
How much oil does a 1982 yamaha take?
Hello, the XS400 Takes around 3 quarts of oil. There should either be a dipstick or window in the crankcase. The oil should be visible in the window,if it isnt add more until it is. If it has a dipstick for the oil, check the level, it should be up to the full mark but no higher. I hope I have helped you.
Mar 23, 2011 | 1982 Yamaha XS 400
Bikemaster 1981-1983 Yamaha Xj750r Seca Motorcycle Clutch Lever Black Logo
15 people viewed this question
Top Bikemaster Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Bikemaster Cycling Expert? Answer questions, earn points and help others
