Electrolux esf 2440 error 50 - Washing Machines
2 Suggested Answers
Electrolux ESF 65010. How can I erase failure code if the problem is solved and start test program?
Here's the manual link
WWW.manualslib.com/manual/602210/Aed-Electrolux-Esf65010htlm?page4#manual
Apr 10, 2017 | Electrolux Dishwashers
Hi, My Electrolux dishwasher ESF 45030 has got locked and the control panel is not working anymore, could you please help me to fix it?
All of the manuals I can find are in a language other than english.
Not much help here.
if there is a child lock under a button or two hold it/ them down for 3 seconds or until you get the controls to light up.
Apr 18, 2014 | Electrolux Dishwashers
Dishwasher ELECTROLUX ESF 6121 WHEN STARTING propels the water, and then stop and blink SIJALICE WASHING AND PROGRAM. PROVERENO solenoid which operates. WHAT IS THE PROBLEM. Thank you, Darko
this fault can be the heater which has an electrical earth fault. You need an insulation tester to test it. The heater is accessed from the right hand side and is a cartridge type insert in the flow to the top spray water supply.
Nov 06, 2010 | Electrolux Dishwashers
Electrolux ESF 662 no water is taken into the machine
Mine did the same thing. Turned out it was leaning back a bit, so I leveled it and now it seems to be working fine.
Mar 08, 2010 | Electrolux 23 in. ESI602 Free-standing...
Electrolux dishwasher shows code 10 not filling fault and code 20 not draining fault but when running you are able to hear it filling and draining. Whats the problem.?
I had the same issue (Electrolux ESF 6251). I had both error codes 10 and 30. I found that the short hose connecting the inlet valve (solenoid) to the tank was cracked. That explained error code 30, but even after replacing the hose I still got error code 10. I checked water supply and also drain hose and filters. I realized that I had recently tried to flush out lime scale and suspect that the drain or pump had lines could have clogged up. I tried pumping into the floor drain inside the dishwasher (removed the filter cartridge and screen) simply with a suction cup like you use in the kitchen sink. Voila. Now it works again...
Sep 17, 2009 | Electrolux Dishwashers
Dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
Mar 01, 2009 | Dishwashers
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
