FixYa.com
Tags:
Panasonic CQ-C7301U CD Player
Don't keep memeory (by 2 users)
posted by camaro72 on Aug 29, 2007
OK,SOME REASON MY PANASONIC CQ-C7301U DON'T WANT KEEP THE MEMORY,EVERYTIME I TURN THE UNIT OFF AND THEN BACK ON ,THE STATION SELECTED BEFOR THE NO'T THERE ENYMORE.
I TRY EVERYTHING.THANK'S FOR YOUR TIME.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by GEZZIE, posted on Mar 28, 2008
CANT KEEP MEMORY.. I HAVE BOTH YELLOW AN RED TOGETHER.. SO WHATS WRONG.. I HAVE A DEH-P580MP... TIRED OF SETTING THE BASS AND TREB......
Solution #1
posted on May 30, 2008
Not Rated (0)
benlax1611
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Your Constant (Yellow) and your Power (red are not suppose to be connecting to the same wires... Easiest way to fix, test the wires with a voltage meter, find a wire that is hot( always with power no lose of power when car is on/off that is your CONSTANT wire where you would plug you constant wire on(yellow which will keep your time/ memory saved) then plug the Red where it is( since you know it is not a contant(always hot with votage when car is on/off) this will make sure when you turn your car off your radio will turn off BUT still save memory due to you having your constant pluged into a REAL constant wire that has voltage at all times. Email me if you have any additional questions.
Ben
benlax1611@aol.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 31, 2007
Not Rated (0)
ampman
Rank:Wiz Wiz
Rating: 83%, 64 votes
Hi... your stereo has 2 power wires. Typically One is yellow and the other is red. Both should have power with the key on. Only one should have power with the key off..
the most common causes for what you are describing are either no constant power to the radio on one of the wires or you have the red and yelow wires switched around...
-ampman
Can you Help with these In Dash Receivers problems?
In Dash Receivers
Owners Manual Pioneer DEH-9
I've searched every site I can... Answer This...
installation manuel
need installation instructions... Answer This...
after 2 years my subs quite... Answer This...
no sound...
but if the unit was grounded,... Answer This...
wiring
what is the broiwn wire for?... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
