Question about Fountainhead/Burgess Prod Black Flag Propane Fogger
Foggers black flag fogger will not stay lit. Lie it and it flkkers for a few seconds then goes out
Parts list for black flag fogger
Where do I buy a replacement front mesh cover??
May 22, 2013 | Fountainhead/Burgess Prod Black Flag...
What does tick control on the environment mean?
Environmental tick control refers to both the yard and kennel areas. You should find an environmentally-safe spray to use and follow the instructions carefully. If you come across an indoor tick problem you need to use a flea and tick fogger. Check the cracks around windows and doors. Here is a good tick control fogger you can use: http://www.petco.com/product/7322/Hartz-Control-Pet-Care-System-Home-Foggers.aspx
Aug 01, 2012 | Pets - Others
How to troubleshoot this fogger
I would take it back to the place that you bought it or contact the manufacturer and tell them that it's not working properly.
But first i would make sure all the parts are secured in and the batteries are working properly.
Jun 18, 2012 | Hagen Exo Terra Mini Fogger
Trigger is not pumping properly
The plunger needs a new leather, but question is where can you buy it. The problem is caused by the side pull on the plunger causing it to wear unevenly to one side. Could be solved in the manufacture if they would build the trigger to pull it up evenly.
Jul 10, 2011 | Fountainhead/Burgess Prod Black Flag...
Shoots liquid not fog
you need to let it fully heat up first!
Nov 15, 2009 | Fountainhead/Burgess Prod Black Flag...
My fogger is new from last year, never used, it only worked for 5- minuites and makes a loud bezzing sound.
Yes I did.
There was no replies from all the e-mails I sent,
so I might sue the company for 3 dead foggers and go with another
brand of foggers.
Rob.
Oct 20, 2009 | Gemmy Toys
Machine seems clogged
Hello, i just finished a successful repair. i did have to take it apart, and there were springs and ss balls(at fog liquid pickup end that i unscrewed to give easy access to blocked pipe) and such so work where parts won't be easily lost and pay attention during disassembly. The problem with mine(several years old) was blockage in the metal line(pipe) that carries the fogger liquid. i used carborator cleaner and a compressor hose with low pressure. i sprayed in the cleaner and then put air pressure each way back and forth till it eventually yet suddenly cleared out then allowed unobstructed passage. then flushed it to clean it well. BE CAREFUL, it can suddenly spray the cleaner out, safety glasses saved me from a bad accident but my face and lips were stinging from the cleaner, and that was with the end facing away from me(but into a bucket and it bounced back at me). Anyway, reassembly took a bit but now it fogs great again. Mine might be a different manufacturer(burgess) but most likely the same basic scenario. Best wishes
Jun 27, 2009 | Fountainhead/Burgess Prod Black Flag...
Fogger does not produce fog
It is common for the nozzle to plug up. If it is brass, it will unscrew and can be cleaned with a very small drill bit.
May 31, 2009 | Fountainhead/Burgess Prod Black Flag...
Fountainhead/Burgess Prod Black Flag Propane Fogger Logo
288 people viewed this question
Top Fountainhead/Burgess Prod Garden Experts
Dennis Key
Dennis Key
john h
Are you a Fountainhead/Burgess Prod Garden Expert? Answer questions, earn points and help others
