Sharp mx 2310u
Maintenance required code dk
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
  • 373 Answers
SOURCE: Sharp-MX2700N Maintenance Code VK
Did you try sharp.com/maintenance
Posted on Feb 04, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
007tech
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
SOURCE: Sharp error codes
What does error code 808 and binary Alert mean?
Posted on Apr 01, 2010
Sim 66-10; What does The confidential data mean?
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
This data will be cleared if Sim 66-10 is enacted.
Mar 01, 2015 | Sharp MX-2310U Color Printer : 2310U
"Sim 66-10"; What does "The confidential data" mean?
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
How can I delete the Memory of RESENDFAX for MX-2310?
Try this while you're at it.
# * C * to enter the simulation mode.
Simulation 66-10 is the image memory clear which clears the print/scan/fax memory. DO NOT EXECUTE AND OTHER SORT OF CLEARS IN THE MENU.
Copier Collin Houston TX Copier and Imaging Expert
Feb 08, 2015 | Sharp MX-2310U Color Printer : 2310U
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
Error code C1-14
Problem with the charger inside one of your drum cartridges. Inside the cartridge frame there's a charge sawtooth and grid which feeds and discharges voltage to your drum. This is a one-piece unit which gets swapped out from the maintenence kit. HOWEVER, IF your copier is at a high altitude, Sharp just published a bulletin saying you need to upgrade your Main Charge board.
Apr 08, 2013 | Sharp Mx-2310u Color Copy/print/scan
Getting maintenance code DK...What is it referring to?
DK refers to the counter for the black developer powder.... a service call will be needed for this
Feb 17, 2010 | Sharp MX-2300N Color Copier
Dec 23, 2008 | Sharp MX-2300N Color Copier
50 people viewed this question
k24674
jasbo
jasbo
