Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Boom Mic is broken
My son cranked the boom in the wrong direction and broke the boom mic connection. I am sure that I can fix it, if I can open it. I tried various methods to open the boom so that I can access the wires within, but have not been successful as yet. I am scared that if I apply more pressure I will certainly break it. Please help or point me to the right direction. It would be nice if someone can provide pictures on how to open it or a service manual. Thanks soo much
    Genius:
  • 1,003 Answers
Go to www. n1wirelss.com you can get a refurbished one for about fifty bucks with the option to get warranty
Posted on Jan 14, 2008
SOURCE:
My head set seems to be fine ,but the mic. is not working is there a way I can dismantal it and chk to see if I can fix it on my own?
I had the same problem. Upon close inspection of the wire that comes out of the boom mic, I found that it was frayed and if manipulated I could get some function out of it. I took off the speaker on the boom side, the one screw holding the boom and the circuit board so I had a little more freedom to move the components around on the desk.
The thing that stumped me for awhile was how to take the boom apart because the wire damage was partially inside the boom. It took a great deal of force, but with a knife I got it to snap apart. Then the wire repair. This wire is an inner core and outer casing. I did not have any spare to replace the whole thing, so I carefully separated the strands from the two conductor 'streams'. I did a hack solder job which required the wire to be shorter, but there was enough slack to do that. The boom has some in and out adjustment, so I put it all the way in to help make up for the shorter wire. I did not make enough room to use shrink wrap, so I had to use tape to insulate between the two.
I tested it in it's disassembled state and it worked, so that is good until I find some similar wire to replace the whole strand. I wont move the mic up and down as that was the source of the original fatigue even though the mute function on mic up wasn't working so I did not use it often anyway.
May 19, 2013 | Plantronics .Audio 995 Digital Wireless...
Plantronics Noise Cancelling headset H261N hearing others problem
where is the other end of your amplifier connected? To a computer, to a phone?
Did you connect correctly the mircophone to your amplifier and from your amplifier to the correct plug?
Oct 20, 2007 | Plantronics (43-1960) Headphones
I cannot get my phone to locate my motorola hs850 what do i need to do?
close the boom mic , press the button and hold until blue light is solid and with your spare hand flip the boom mic back open and the light should remain on. "0000" is the default passkey
Jul 05, 2009 | Motorola Mobility HS850 Consumer Headset
How do i connect motorola hs850 with lgcu720 (shine)
Make sure the book mike is closed, then press the button until the light changes color. Once it changes color, open the boom mike. Now the earpiece is in pairing mode.
Feb 08, 2009 | Motorola Mobility H700 Wireless Headset
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
if you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
MY JOB DEPENDS ON THIS! SONY DSR PD 170 AUDIO PROBLEMS
1- Does built-in mic work?
2- Connect direct mic and check sound instead of wireless mic and confirm camera audio circuit.
3- It is Sony professional camera and this should be repaired by Sony qualified technician as you stated that your job depends on it so don't take risk. Attempt of repair by unqualified person is not advised.
Hope this info will help you.
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
My headset wil not turn purple after holding it for 5 seconds
You need to hold down the call button before opening the mic. Once it turns purple immediatly open the mic. If you wait too long to open the mic after it turns purple it will turn blue or just go out.
Aug 26, 2007 | Motorola Mobility H700 Wireless Headset
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
114 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
