Question about LeapFrog LeapSter L-Max Console
Reset leapster I have tried many times to reset or calibrate Leapster L-Max but cannot get center cross to respond. What next?
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Leapster L-Max dies after 10 min
A cheaper alternative is to use the rechargeable battery pack.
Regular nicad batteries are not equipped to handle electronics like this.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 02, 2009
  • 3 Answers
SOURCE: i have leapster l-max and
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Posted on Apr 15, 2011
Leapster GS screen upside down
I would try resetting it. You could also try calibrating the screen. The GS screen has a static orientation, so this seems like a very odd problem.
Leapster Explorer or LeapsterGS Explorer screen is not responding to the...
Aug 16, 2013 | Toys
How do i recalibrate the leapster gs screen stylus and screen
SolutionIf your Leapster system does not respond to the stylus pen, it needs to be calibrated. To calibrate your Leapster system:
  1. Turn the unit on and wait for the sign-in screen to appear.
  2. Hold down the Home, Hint, and B buttons simultaneously.
  3. When the screen changes, press the A button.
  4. Using the Stylus, touch the center of the targets.
Jan 28, 2013 | LeapFrog Toys
How do you calibrate the leapster learning game system?
  • Follow these steps to calibrate your Leapster Learning Game system -
  1. Remove any game and turn the Leapster off.
  2. Turn the unit on.
  3. When the sign in screen appears immediately press and hold down "home"(house), "hint"(question mark), and "B" buttons together for 4 seconds.
  4. Now you will see a few options.
  5. Press the "A" button for the touch calibration option.
  6. Now just touch the stylus on the cross-hairs and it will be calibrated.
  7. Now you want to restart the unit.
  8. Redo the steps if this should not work the first time.
Regards, Tony
May 19, 2011 | Toys
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
Screen calibration doesn't work on Leapster 2. Touchscreen doesn't function properly. Used calibration technique and it still wont work. New Leapster, purchased at Christmas.
CALIBRATION - summary of hints from here that eventually got our circa 2007 green leapster's screen recalibrated - in no particular order: 1) "home+hint+B" to get started, 2) "A" button next, 3) cleaned dirt from the gap between the plastic and the screen all the way around with a toothpick (seemed to be the KEY ELEMENT to get everything else to work), 4) be patient and keep trying until you see the targets - the first one should appear in the top left corner while the text is still on the screen, 5) if it doesn't work just right the first time try again, 6) unit should beep each time you press a target center.
Mar 29, 2010 | LeapFrog Leapster Electronic Book:...
The touch pen doesn't work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Nov 28, 2009 | LeapFrog LeapSter L-Max Console
Leapster 2 asking to choose usa or canada but unable to select
Try calibrating the screen:
(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.(2) Hold down the Home, Hint and B buttons simultaneously.(3) When the screen changes, press the A button.(4) Using the Stylus, touch the center of the targets.
Aug 06, 2009 | Leapster Learning System
Leapster doesn,t respond when the pen touch screen
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Sep 29, 2008 | LeapFrog Leapster Electronic Book:...
Leapster with broken pen
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
Leapster screen
Sounds like it needs to calibrated - see http://gobaco.wordpress.com/2006/10/31/how-to-calibrate-the-leapster-handheld/
for info,
Feb 19, 2008 | Video Game Consoles & Games
LeapFrog LeapSter L-Max Console Logo
35 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Dustin
Dustin
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
