Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Need help
The timer needs to be reset is it possible to reset it with universal remote
    Top Expert:
  • Panasonic Master
  • 12,223 Answers
You can go to the MENU and use the restore factory default.
God bless you
Posted on Jul 25, 2013
Can i use a rca universal remote to reset the lamp timer on my Zenith D60WLCD 60" Rear Projection HDTV-Ready Television? I have lost the original remote and have replaced the bulb
Probably not. You need to get into the "utilities" menu, which is only accessible via the original remote (or possibly via buttons on the TV).
Apr 07, 2015 | RCA Televison & Video
Can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
Mar 26, 2012 | Panasonic PT-50DL54 50" Rear Projection...
Can i use a universal remote to reset trap switch on pioneer pro 1150hd 50in. tv
To get into service mode you need the genuine remote control, A universal one will not work.
Mar 06, 2012 | Pioneer Televison & Video
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
The universal remote that I had been using for a few years started needing to be reset (without a code) every couple of days and eventually could not be reset. I thought it was the remote and tried a...
Hi, Not usually especially if the remote had a sleep timer button. the only excception is if the tvis fitted with buttons for accessing/navigating the menu functions from the local keyboard.
A quick way to verify if theremote is outputting any IR is to view the front of the remote with a digital camera/ phone camera etc whike pressing a button. you will normall see a white flickering light if all is well. note this doesn't confirm if there is good signal - more only an indication the remote is operational
Aug 13, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
On my pt 52lcx35 it says the lamp hour meter needs to be reset.
press the down volume on the tv at the same time press the up dvd/vcr split button on the remote. do this for at least 5 seconds and it should reset
Apr 02, 2009 | Panasonic PT-52LCX66 Projection Television
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
JVC HD-52G786 Service Mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Jun 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Cinego replacement factory remote control will not operate the projector
Go and buy a universal remote with button memory capability. (able to learn any remote function). That works great for me.
Apr 28, 2008 | Radio Shack Cinego D-1000 Multimedia...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
