Question about Refrigerators
Kenmore Refigerator Ice maker
I just moved into a home with a Kenmore refrigerator at the location. The freezer is equpt with an ice maker but i'm not sure how to operate it. Any help?
  • 75 Answers
First, ensure that you have water connected to the intake tube at the back. The water filter needs to be checked also. It is in the cooling section(not the freezer), at the top. If it looks old or water does not flow, it will need replacing. Depending on the model, there is a switch inside the freeze section behind the ice tray. Turn that on, and ice should be available after a few hours. Some models don't have a switch, but a wire hanger, that needs to be in the down position for the ice maker to work.
Posted on Aug 30, 2007
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Lower wire if it is up. other than that u may have to turn the water on behind box
Posted on Jul 26, 2009
SOURCE:
My kenmore refigerator ice maker stopped making ice.
Could be that the solenoid that feeds water to the ice maker is not working properly.
Also make sure that the freezer temp is at least 10 degrees or less - if not the ice making cycle will not commence.
Mar 12, 2017 | Kenmore Refrigerators
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cant find the ice maker filter on my kenmore elite bottom-mount refigerator
It is on the back - behind a removeable panel. Top left side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Where are the temperature controls on the kenmore elite bottom freezer refigerator
Here is a shortcut to drawings that might help you. They may have your refrigerator on this site.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
My maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Ice Maker; Kenmore Elite
you have an bad fan motor or wire connection to the fan that is used for the ice maker..hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
1,183 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
