Question about Radio Communications
User manual for smc 517l10 hand held transceiver
cheebster
  • 39 Answers
SOURCE: Electronic Manual
Hi there. Here are the docs you need ; This is a quick reference guide : http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3384903apdf&sliceId=&dialogID=2488809&stateId=0%200%201025855 This one is the user's manual : http://www.guardit.cn/UploadFiles/symbol_ls400xi_engmanual.pdf And this one is the advanced programming guide : http://www.ausense.com/pdf/LS4000_APG.pdf The LS400XI as refered in those docs in the same scanner as the LS4004i. Hope that helps ! :) cheebster.
Posted on Jun 18, 2007
Benimur
  • 6966 Answers
SOURCE: general electric
Initially the only easy user action possible is to check/clean the battery contacts/terminals.
If still a no go, you need to check for any loose or open wiring from the battery compartment to the PCB. That would mean opening the unit and having a look & see inside. You need to be familiar with electronic components and circuitry, DVM and possibly a soldering iron. You need to look/check the power switch, voltage regulator, reverse protection diode, zener diode, fuse/fusiblelink-resistor, open foil/trace and any other components associated with the power supply/regulation.
If this does not solve the problem, your best bet would then be to seek the assistance of a qualified communications technician.
Hope this be of help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Dec 24, 2007
  • 138 Answers
SOURCE: realistic trc-216
have you installed the antennas correctly?
Posted on May 12, 2008
naebarbat
  • 508 Answers
SOURCE: Technical Specs and User's Manual
try this:
http://inform3.kenwoodusa.com/manuals/kdcx492.pdf
Posted on May 29, 2009
kd6rhd56
  • 400 Answers
SOURCE: need a user manual for the Maxon hcb-10a hand held
www.cb-radio-shop.com/handheld-cb-radio
Hope this helps
Posted on Jul 12, 2009
Kenwood 220 hand mixer manual
Hi Charlie,
You query was posted on the two way radio forum by mistake, could you re-post on the kitchen ware forum, so you can find the answer there.
Cheers,
Peter
Mar 18, 2013 | Kenwood TH F6 A 144/220/440 Handheld...
My ipod touch wont connect
There are firmware updates available for this router available at the SMC Support Web Site.
Follow the link to "Firmware" under "Support" on the left-hand side. Apparently there are two different part numbers associated with the SMC2804WBR model number. Check the label on the router to determine which part number is yours.
Download the firmware update and apply the update according to the user manual, which is also available at the link above.
If this does not resolve the issue, then this router may be outdated and unable to support your iPod Touch.
Dec 28, 2010 | SMC Wireless Cable Router...
I've got a 2001 Dodge Intrepid and it came with no Manual. I need to know what all of the buttons are for above the front window rear view mirror. And that's all! Thanks a lot!
According to the manual the buttons are for the HomeLink Universal Transceiver which replaces up to three remote controls hand held transmitters) that operate devices such as garage door openers, motorized gates, or home lighting. It triggers these devices at the push of a button.
For more information visit homelink.com
Jan 27, 2009 | 2003 Dodge Intrepid
Open gurage door with the built in remote in the car
To Reprogram A Single Button
1. Press & hold the desired universal transceiver button. Do not release the button until Step 4 has been completed.
2. When the dot(s) under the HomeLink icon being to flash slowly (after 20 seconds), position the hand-held transmitter 1-3" away from the universal transceiver surface.
3. Press & hold the hand held transmitter button.
4. The universal transceiver light will flash, first slowly and then rapidly. When the indicator light begins to flash rapidly, release both buttons.
The previous programming for the button has now been erased and a new device has been programmed to the button.
Repeat for any other buttons you want to do for other devices.
Dec 20, 2008 | 2001 Chrysler Town & Country
Realistic trc-216
Apr 27, 2008 | Radio Communications
Radio Communications Logo
235 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
