Question about Bosch Dishwashers
Dishwasher programme stuck
Hi my hydro sensor got stuck at the end of the cycle , it's 13 years old so we were going to bin it , we noticed in the shop while looking for a replacement that there was a recall on various models , due to a fire risk , ours was one of those affected , bosch came out replaced a faulty part , as a recall and now it's working again :) no need to splash out on a new one the engineer said our part had just failed not caught fire so that was a result!
  • 14 Answers
SOURCE: Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Posted on Jan 17, 2008
SOURCE: bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Posted on Mar 27, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
jsrock516
  • 5911 Answers
SOURCE: Our Kenmore Dishwasher caught fire.
You may want to contact Sears to see if there was a recall on your model dishwasher. There were problems with the door assemblies on some model dishwashers that were caused by the rinse agent leaking into the wire harness of the door. Over time the rinse agent would corrode the wire insulation causing the units to catch fire in some cases. The fix was a free inner door and wiring harness upgrade kit from the manufacturer. Here is a link you can refer to that may offer some assistance:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07190.html
Although I did not see your model number listed, you may want to call the Consumer Product Safety Commission number listed at the bottom of the page and report this incident.
I hope this offers some assistance to you.
Posted on Sep 17, 2009
Testimonial: "Gave me just the info I needed."
SOURCE: whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Posted on Mar 13, 2010
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
How do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Apr 22, 2012 | Dishwashers
Hi, my Siemens SE25A836GB Hydro sensor dishwasher won't drain after it finishes the programme?
Look inside at the grate in the bottom and make sure it is not blocked.Remove that cover and check for fodd pieces, etc that may be restricting it
Jan 20, 2011 | Siemens 24 in. SE25A836GB Hi-Line...
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 | Dishwashers
Dishwasher stuck on wash cycle and water does not heat up
The element that heats your water may be bad or the control panel(board) could be bad as well. If your machine is older than say 10 years old, it probably is the board. If you can, check the element by feeling to see if it is rusted through or has a rough feel to it in any particular area. The signal telling it to go into the rinse phase is an indication the the board is bad. Is it still under warranty?
Dec 13, 2008 | Zanussi 18 in. DE4744 Free-standing...
Westoint Dishwasher
Hi jannewbery,
I'm Harvey the Master Plumber.
Your problem is: You have looked in the manual under troubleshooting tips, but didn't find anything on the problem. The dishwasher goes into cycle,but during the wash cycle it stops,makes alarm and the wash and rinse ligts come on. And now you can't even find the product on this site.Westpoint Dishwasher WQP12-9240.
Thankyou Your dishwasher is stopping at stage 2 of the programme after beeping once. Quite often the detergent flap doesn't open. Am at your wits end and threatening to leave home!!!! The machine is less than a year old. PLEASE HELP!!!! Thank you.
Don't leave just yet. It sounds like a control problem. The d/w should still be under warranty if it is less than one year old. Use it before it runs out. I don't recomend this type of repair for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
Dishwasher seems to b stuck on drain cycle
Model and serial number ???Helps alot
Jun 11, 2008 | Dishwashers
Dishwashers Logo
32 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
