Question about Electrical Supplies
Yardworks generator My friend has a yard works generator I think its a 2150 . He says it will start and run but it doesnt run anything that you plug into it. It dont seem to produce power like if you plug in a drill , the drill wont run. can you help him out and tell him whats happening. Thanks.
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
ccrozier_agr
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
CarlGehrke
  • 169 Answers
SOURCE: coleman 1850 sport, no/ low generator output
The engine should run at 3750 rpm at no load. If that's OK then you may need to troubleshoot the capacitor inside the end of the generator opposite the rope. Since the thing has been stored for some time you may just need to flash the field of the generator to restore the residual magnetism in the rotor. The easiest way to do this is thru the 110 outlet but it's a little dangerous. Plug an old lamp cord into the outlet, start the generator, and momentarily connect a 9 volt dry cell to the wires, then shut the generator down and see if there is 110 when you restart it.
Regards,
Carl
Posted on Feb 23, 2009
SOURCE: Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
Posted on Jul 29, 2009
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
I have a yard works 2150w portable generator. It runs for 20-30mins then quits running. I think it is a exhaust issue. My question is how can I fix this or can it be fixed?
more likely a coil or ignition module problem or a problem with the oil level cutout system
They can over heat internally in an electronic component and will not start again until that system cools down
It has a very small exhaust and if that was a problem , it would be playing up less than 5 minutes of running
Apr 09, 2016 | Electrical Supplies
I obtained powerstroke generator 5000w from friend never used, when started up runs at 7300 RPM, what is best RPM and how to adjust to proper RPM's
depends on the power drain
if you have less plugged into a generator it can run slower.
if you have 5000 watts plugged in it needs to run faster.
Mar 25, 2016 | Electrical Supplies
My yardworks 2150w portable generator wont start. Thought it was dirt or water in the gas cleaned it all up .not working. Lots of spark no start. Help
My yardworks portable generator 2150 won't start - Fixya
www.fixya.com/support/t14802132-yardworks_portable_generator_2150
Oct 28, 2012 - First check the circuit breakers on the control/outlet panel. Then take the end off the generator and look at the brushes (usually what breaks) and the ...
Why won't my portable generator start? - Home ...
diy.stackexchange.com/questions/.../why-wont-my-portable-generator-st...
Mar 6, 2013 - The generator is fairly new -- I bought it at the end of June '12. ... An E 3 spark plug is always a good start, Stabil (fuel stabilizer)in the fuel or ...
the generator in parts, accessories - Alberta - Kijiji
www.kijiji.ca > Alberta > cars & vehicles > RVs, campers, trailers KijijiLittle hours on this generator comes with command start was over $ 500 just for the starter. Yamaha ... Yard Works 2150w generator. Generator starts ... Wanted generator for my camper at least 1500 or more ... You won't see more new motorcycles at one place anywhere else. ... New Champion 4000watt portable generator.
Power Generators New ' Kijiji: Free Classifieds in Alberta ...
www.kijiji.ca/b-alberta/power-generators-new/k0l9003 Kijiji
Dec 18, 2015 | Electrical Supplies
Is there a filter on the 24v lawn mower made by Yardworks?
No. Because it is electric, not gas powered.
Jul 18, 2014 | Garden
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Yardworks 3500 generater back fires
I need a gas tank for yardworks generator 3500 can you help me?my add.jacques486@sympatico.ca
Jan 11, 2012 | Electrical Supplies
Ihome ih9 wont work with 3rd generation ipod nano
Look at the Box and the Manual! 3rd Generation is not supported by iH9! Clearly marked on the Manual.
Jan 03, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Culitvator yard machine, suddenly stopped working
try changing the spark plug, if that doesnt work let me know and i'll help you trouble shoot it further
Oct 02, 2008 | Yard Machines Garden
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
