Bosch wfx2867 manual - Washing Machines
Need a manual for bosch front loader wkm41
http://laundry.manualsonline.com/manuals/mfg/bosch/800_series.html . That should be the manual for the bosch wkm41. If not get back to me and i'll take another look. Also the bosch website has manuals searched by serial number if you get too stuck.
Dec 28, 2014 | Bosch Washing Machines
Wfx2867/gb fault code fc04 shows. what does this mean?
hello,
The Fc04 is an error code that means indication of a water temperature sensor error over flow from it range which level is below 05'c
what you have to do to fix up this problem is to unscrew (open)the washer then clean up all form of water from the wire and also on the screen /panel then couple it back and allow it to relax it self for some time.
please DO NOT APPLY WATER when doing this and also make sure that all surce of power supply is put OFF from the switch
thank you and thanks for using fixya.
Jun 12, 2010 | Washing Machines
Bosh WFX2867 Carbon brush replacement
The worn out brush could certainley cause the trip to operate.
The best way to remove motor is to lay washer on it's side, and undo the 2 screws that hold the motor in place, then lever back off the mounts.
Remove the rear cover first and drive belt.
Hope this is if some help to you .
Please rate my solution.
Thankyou.
Jan 23, 2010 | Bosch Washing Machines
I need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Aug 31, 2009 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
